Go Back   Vista Forums > Vista Newsgroups > Vista print fax & scan
Vista - HP printer problems on Vista by novice
Old 05-28-2008   #1 (permalink)
vista home premium
Hi
Can anyone please help?
I am by no means an expert on the Vista system, and am currently stumped by trying to remove (delete) an installed printer (HP1210 all in one). I have tried all usual channels but am still seeing printer and stating deleting! If I click on the printers properties it says that there is one job still to do, but it is impossible to cancel and/or remove this, thus no completion on deleting printer.
Thanks for all constructive help
Old 05-31-2008   #2 (permalink)
Cari \(MS-MVP\)
Re: HP printer problems on Vista by novice
Check HP;s website under your exact model to see if they have an uninstall
utility that you can download and use.
Cari (MS-MVP) Printing & Imaging
www.coribright.com/windows
"STUMPS" <guest@xxxxxx-email.com> wrote in message
news:c9c1d0ac631ab862d30999474247ea3a@xxxxxx-gateway.com...
Quote:
> *Hi
> Can anyone please help?*
> *I am by no means an expert on the Vista system, and am currently
> remove this, thus no completion on deleting printer.*
> *Thanks for all constructive help*
> STUMPS
Old 05-31-2008   #3 (permalink)
vista home premium
Thanks Cari,
Managed to remove eventually but took a very long time. Unfortunately the printer is a bit old and HP didn't carry any links or uninstall devices on it at all.
I appreciate your comments.
Regards,
Steve
Old 05-31-2008   #4 (permalink)
Cari \(MS-MVP\)
Glad you and 'it' are OK, IMHO all AIO's should have an uninstall utility
available at the manufacturer's website!
news:339b60c7f3f4e2f64542302f19900916@xxxxxx-gateway.com...
Quote:
> Thanks Cari,
> Regards,
> Steve
> STUMPS
Problem deleting HP printer on Vista by novice General Discussion
HP printer problems on V ista by novice Vista print fax & scan
xp to vista - novice Vista installation & setup
novice- router problems Vista networking & sharing
Vista is not for the novice Vista General
