| | Vist 64 bit problem with HP Scanjet 4050 Scanner Hi: I have a Scanjet G4050. I am running HP's Solution Center Software which uses the HP Scan software ("hpqscnvw.exe"). I am running Windows Vista Home Premium 64 Bit with 6GB of RAM, Intel Core 2Quad Q6700, Nvidia GFORCE 8600GT, Norton Internet Security. I just got the computer and the scanner in April 2008 and it appears that document scanning works. However, the scanner software crashes when I try to scan multiple 35MM film negatives. The G4050 has a TMA that holds five strips of negatives with six frames each. It especially crashes when scanning Black and White 35MM negatives (256 Gray scale). The error message is first "hpqscnvw has stopped working" and then "An unexpected internal error has occurred. Click OK to close the program and then try one of the following..." Windows Event viewer says the faulting module is "ntdll.dll" which is one of the core WIdnows Kernels I believe. I have uninstalled all imaging software and reinstalled the latest, installed the tablet pc patch, and spent time with HP's imaging helpdesk. They can offer no solution and say it is a Vista problem. My own guess is that it has something to with the 64 bit and 6GB of RAM. The scanning software appears to put the images into short-term memory and as that cache builds up, somehow either Windows or the HP software is not handling the memory correctly, so the app freezes. I had a different problem with Google Earth (which I found out does not support 64 bit apps) and in reading up on the issue http://groups.google.com/group/earth...fd566dfb380b51 I noticed that the problem I encountered with GE is due to GE not recognizing the memory in a 64 bit configuration. So, I wonder if 1) Vista 64 bit is having problems allocating memory for the HP scanner software or; 2) if the HP scanning software is having trouble with the short-term memory or; 3) the HP scanning software and solution center software is, in fact, not Vista 64 bit compatible (which is not what HP says) 4) something else Does anyone have any ideas? thanks |
| | Re: Vist 64 bit problem with HP Scanjet 4050 Scanner I'd probably put my $s on #3 but the easiest way to tell is to remove some of the RAM (to make it 3gb or less) and see how the scanner performs with the maximum amount of RAM a 32-bit Vista PC is able to read and use. Please let us know what happens. -- Cari (MS-MVP) Printing & Imaging www.coribright.com/windows "David Levine" <DavidLevine@xxxxxx> wrote in message news:48D4817E-0BFA-40ED-9EC4-929C0A4D4B27@xxxxxx Quote: > Hi: > I have a Scanjet G4050. I am running HP's Solution Center Software which > uses the HP Scan software ("hpqscnvw.exe"). > I am running Windows Vista Home Premium 64 Bit with 6GB of RAM, Intel Core > 2Quad Q6700, Nvidia GFORCE 8600GT, Norton Internet Security. > I just got the computer and the scanner in April 2008 and it appears that > document scanning works. > However, the scanner software crashes when I try to scan multiple 35MM > film > negatives. The G4050 has a TMA that holds five strips of negatives with > six > frames each. It especially crashes when scanning Black and White 35MM > negatives (256 Gray scale). > The error message is first "hpqscnvw has stopped working" and then "An > unexpected internal error has occurred. Click OK to close the program and > then try one of the following..." > Windows Event viewer says the faulting module is "ntdll.dll" which is one > of > the core WIdnows Kernels I believe. > I have uninstalled all imaging software and reinstalled the latest, > installed the tablet pc patch, and spent time with HP's imaging helpdesk. > They can offer no solution and say it is a Vista problem. > My own guess is that it has something to with the 64 bit and 6GB of RAM. > The > scanning software appears to put the images into short-term memory and as > that cache builds up, somehow either Windows or the HP software is not > handling the memory correctly, so the app freezes. > I had a different problem with Google Earth (which I found out does not > support 64 bit apps) and in reading up on the issue > http://groups.google.com/group/earth...fd566dfb380b51 > I noticed that the problem I encountered with GE is due to GE not > recognizing the memory in a 64 bit configuration. > So, I wonder if > 1) Vista 64 bit is having problems allocating memory for the HP scanner > software or; > 2) if the HP scanning software is having trouble with the short-term > memory > or; > 3) the HP scanning software and solution center software is, in fact, not > Vista 64 bit compatible (which is not what HP says) > 4) something else > Does anyone have any ideas? > thanks > |
| | Re: Vist 64 bit problem with HP Scanjet 4050 Scanner Cari- Yes, it was in fact due to the HP software the drives the scanner - I am working with their developers. it is a bug with respect to how it scans Black & White Images and has nothing to do with Windows... "Cari (MS-MVP)" wrote: Quote: > I'd probably put my $s on #3 but the easiest way to tell is to remove some > of the RAM (to make it 3gb or less) and see how the scanner performs with > the maximum amount of RAM a 32-bit Vista PC is able to read and use. > > Please let us know what happens. > -- > Cari (MS-MVP) Printing & Imaging > www.coribright.com/windows > > "David Levine" <DavidLevine@xxxxxx> wrote in message > news:48D4817E-0BFA-40ED-9EC4-929C0A4D4B27@xxxxxx Quote: > > Hi: > > I have a Scanjet G4050. I am running HP's Solution Center Software which > > uses the HP Scan software ("hpqscnvw.exe"). > > I am running Windows Vista Home Premium 64 Bit with 6GB of RAM, Intel Core > > 2Quad Q6700, Nvidia GFORCE 8600GT, Norton Internet Security. > > I just got the computer and the scanner in April 2008 and it appears that > > document scanning works. > > However, the scanner software crashes when I try to scan multiple 35MM > > film > > negatives. The G4050 has a TMA that holds five strips of negatives with > > six > > frames each. It especially crashes when scanning Black and White 35MM > > negatives (256 Gray scale). > > The error message is first "hpqscnvw has stopped working" and then "An > > unexpected internal error has occurred. Click OK to close the program and > > then try one of the following..." > > Windows Event viewer says the faulting module is "ntdll.dll" which is one > > of > > the core WIdnows Kernels I believe. > > I have uninstalled all imaging software and reinstalled the latest, > > installed the tablet pc patch, and spent time with HP's imaging helpdesk. > > They can offer no solution and say it is a Vista problem. > > My own guess is that it has something to with the 64 bit and 6GB of RAM. > > The > > scanning software appears to put the images into short-term memory and as > > that cache builds up, somehow either Windows or the HP software is not > > handling the memory correctly, so the app freezes. > > I had a different problem with Google Earth (which I found out does not > > support 64 bit apps) and in reading up on the issue > > http://groups.google.com/group/earth...fd566dfb380b51 > > I noticed that the problem I encountered with GE is due to GE not > > recognizing the memory in a 64 bit configuration. > > So, I wonder if > > 1) Vista 64 bit is having problems allocating memory for the HP scanner > > software or; > > 2) if the HP scanning software is having trouble with the short-term > > memory > > or; > > 3) the HP scanning software and solution center software is, in fact, not > > Vista 64 bit compatible (which is not what HP says) > > 4) something else > > Does anyone have any ideas? > > thanks > > |
| Vista home Premium 64bit | Re: Vist 64 bit problem with HP Scanjet 4050 Scanner Similar issue with scanning multiple photos using the APF with a scanjet 5530. First picture scans, second picture loads, and then when you click "accept" the program freezes. Clicking "cancel" does nothing. Using Solution set software as well. I have gone through the drill of uninstalling software, clearing out registry, reinstalling clean, etc. No luck. |
| vista ultimate x64 | Re: Vist 64 bit problem with HP Scanjet 4050 Scanner a quick fix for the scanner is install a usb 1.1 hub and run the scanner off it. there is a timing issue with the 64 bit and the data is coming too fast for the scanner to handle it. after I installed my hub the scanner worked along with the paper port software. |
| | #6 (permalink) |
| Vista home Premium 64bit | Re: Vist 64 bit problem with HP Scanjet 4050 Scanner Many thanks. Will try and let you know. In the meantime, I installed 3rd party software called VueScan (used a free trial offer, software is not free) that is a complete scanning control suite (it focuses on the scanning task, not editing, presenting, etc.). Little bit of a learning curve to get started and the interface is purely utilitarian, but it has worked flawlessly, including with the apf. VueScan Scanning Software |
| Scanner driver for an HP Scanjet 6200c | Vista hardware & devices | |||
| Vista Home Premium 64 bit error with HP Scanjet 4050 | Vista print fax & scan | |||
| HP scanjet 7400 scanner | Vista hardware & devices | |||
| HP 5100 Scanjet Scanner | Vista hardware & devices | |||
| RE: drivers for an HP Scanjet 2200c scanner | Vista print fax & scan | |||
