br> br> |
| | Thread Tools | Display Modes |
| Guest | Having problem resetting wireless printer After changing broadband IP service, I cannot find the linkage to change the System Password and WEP Key for my HP6800 series wireless printer. The HP instructions for accessing the proper dialog box directs me to the Accessories menu to find Communications, in which Wireless Connection Setup should be available, but in Vista, no such connection exists under Accessories, as it did in XP. How may I resolve this dilemma??? There must be a route, but Help doesn't seem to help!! -- JSullivan |
| | #2 (permalink) | ||||||||||||
| Guest | Re: Having problem resetting wireless printer JSullivan wrote:
service uses a different IP addressing scheme and the printer is a static IP on the old scheme. Usually you administer network printers by opening a browser and going to their IP address. An example: let's say your printer is assigned 192.168.1.200. In the addressbar of your browser (perhaps IE), you'd type: http://192.168.1.200 [enter]. This would bring you to the configuration utility for your printer where you could change it's IP, wireless key, etc. Malke -- MS-MVP Elephant Boy Computers www.elephantboycomputers.com Don't Panic! | ||||||||||||
| Display Modes | |
| Resetting wireless settings on Vista | Camilo | Vista networking & sharing | 2 | 11-02-2007 06:16 PM |
| Problem with Network printer over wireless network. | Russ | Vista print fax & scan | 1 | 10-30-2007 05:19 PM |
| Problem printing in Wireless printer | Pedro Sendas Pereira | Vista print fax & scan | 7 | 10-26-2007 10:25 AM |
| Network Printer and Wireless Network problem | Jim | Vista installation & setup | 1 | 03-07-2007 12:02 PM |
| Default printer resetting | JHoerig | Vista print fax & scan | 0 | 10-05-2006 01:42 PM |
