Go Back   Vista Forums > Vista Newsgroups > Vista print fax & scan
Vista - printer problem
Old 06-14-2008   #1 (permalink)
Andrew
printer problem
My printer is connected to the computer but it doesnt print anything
by Andrew
Old 06-15-2008   #2 (permalink)
Malke
Re: printer problem
Andrew wrote:
Get the correct drivers for it from the printer mftr.'s website. Disconnect
the printer and install the drivers. Connect the printer when the
installation routine tells you to.
If you need more help, go here before posting:
How to Post:
http://www.elephantboycomputers.com/page2.html#Usenet
http://support.microsoft.com/default.aspx/kb/555375 - How to Ask a Question
http://users.tpg.com.au/bzyhjr/liszt.htm - How Not to Get Technical Help on
Usenet
Malke
MS-MVP
Elephant Boy Computers
Don't Panic!
Problem with Dell printer after installation of Vista SP2 (printer prints an extra page) Vista General
printer problem to domain's printer Vista General
Printer problem Vista General
Add printer problem Vista print fax & scan
Lexmark Printer / Error problem communicating with printer Vista print fax & scan
