Go Back   Vista Forums > Vista Newsgroups > Vista print fax & scan
Vista - Vista machine not holding default printer setting.
Old 07-11-2008   #1 (permalink)
windstar2
one of our vista machines will not hold the default printer setting. it keeps
coming unchecked. any suggesstions?
Thanks.
Old 07-11-2008   #2 (permalink)
Alan Morris [MSFT]
Re: Vista machine not holding default printer setting.
What is the OS of the print server you connect to?
Was the connection created using Add Printer or was this a logon script or
other method?
What is the print driver used in the connection?
Is there another shared printers on another machine that you can connect
using Add Printer and set as default?
What is the value under the default printer key
HKEY_CURRENT_USER\Software\Microsoft\Windows
NT\CurrentVersion\Windows\Device?
Is the printer status "Ready" when setting as the default or is it in some
other status.
I'll assume you are logged on as a domain user that does not have admin
rights on the machine.
Can you set the default printer using the command line tools included in
Vista? If this is possible then it points to a UI issue if it's not then we
might get an error.
\windows\system32\printing_admin-scripts\en-us
prnmngr.vbs -t sets the default printer
C:\Windows\System32\Printing_Admin_Scripts\en-US>cscript prnmngr.vbs -ac -p
"\\server\printer"
Microsoft (R) Windows Script Host Version 5.7
Copyright (C) Microsoft Corporation. All rights reserved.
Added printer connection \\\server\printer
C:\Windows\System32\Printing_Admin_Scripts\en-US>cscript prnmngr.vbs -t -p
"\\server\printer"
The default printer is now \\server\printer
Alan Morris
Windows Printing Team
Search the Microsoft Knowledge Base here:
http://support.microsoft.com/search/?adv=1
"windstar2" <windstar2@xxxxxx> wrote in message
news:1620F836-27D5-4617-A7F2-91D6A30DA8D8@xxxxxx
> keeps
> Thanks.
Setting a default printer for the DEFAULT USER Vista print fax & scan
vbscript to cahnge default printer setting from color to b&w VB Script
Problem setting default printer in Vista Vista General
Setting default printer Vista installation & setup
Setting Default Printer to Stay Vista hardware & devices
