| | how to print to usb printer in dos does anyone know how to print to a usb printer in dos from dos prompt. no lpt1 port Parallel port printer. |
| | Re: how to print to usb printer in dos USB to Parallel Converter Cable 1.8m USB to parallel converter cable complete with driver. Type A male USB to 36 pin male centronics connector. a.. To connect a printer with parallel interface (IEEE 1284) to a PC with USB port b.. Easy to install c.. Power supplied by USB interface d.. Connector: Centronics 36 pole male / USB type A male e.. Contents: Converter Cable, Driver CD, Manual Get looking on E Bay for adapters - may help ?? Enter Usb to Parallel port adapter in EBay search. "Ron b." <Ronb@xxxxxx> wrote in message news:9B30A3F1-25A1-4467-B33A-B0ED08800185@xxxxxx Quote: > does anyone know how to print to a usb printer in dos from dos prompt. no > lpt1 port Parallel port printer. |
| | Re: how to print to usb printer in dos In article <7amdnYMYdfr7l-LVnZ2dneKdnZydnZ2d@xxxxxx>, harry@xxxxxx says... Quote: > USB to Parallel Converter Cable > > > 1.8m USB to parallel converter cable complete with driver. Type A male USB > to 36 pin male centronics connector. > > a.. To connect a printer with parallel interface (IEEE 1284) to a PC with > USB port > b.. Easy to install > c.. Power supplied by USB interface > d.. Connector: Centronics 36 pole male / USB type A male > e.. Contents: Converter Cable, Driver CD, Manual user wanted to print to a USB printer from a DOS program or command prompt. That would typically be done by choosing 'LPT1' or 'PRN' as the output. The net sharing I posted earlier generally works unless it's some program that tries to directly access the hardware (relatively rare, thankfully.) -- If there is a no_junk in my address, please REMOVE it before replying! All junk mail senders will be prosecuted to the fullest extent of the law!! http://home.att.net/~andyross |
| | Re: how to print to usb printer in dos http://members.shaw.ca/bsanders/printfromdos.htm Printing from DOS with Windows 2000 or XP This works for Vista, too. Hal -- Hal Hostetler, CPBE -- hhh@xxxxxx Senior Engineer/MIS -- MS MVP-Print/Imaging -- WA7BGX http://www.kvoa.com -- "When News breaks, we fix it!" KVOA Television, Tucson, AZ. NBC Channel 4 Live at Hot Licks - www.badnewsbluesband.com "Ron b." <Ronb@xxxxxx> wrote in message news:9B30A3F1-25A1-4467-B33A-B0ED08800185@xxxxxx Quote: > does anyone know how to print to a usb printer in dos from dos prompt. no > lpt1 port Parallel port printer. |
| | Re: how to print to usb printer in dos No Hal, unfortunately this doesn't work in Vista that way. For hours now, I'm trying to get a dot matrix printer EPSON LQ300 to work together with a DOS program on a Vista Home Premium 32-bit Laptop without physical parallel port. I'm using a simple USB -> Parallel cable for about 20,- Euros. In XP - but not in Vista! - the procedure to get the printer working is as follows: The XP-computer has to be part of a network. Internet connection is sufficient. connect cable & printer. Drivers are installed automatically by Vista. Share the printer. Use a short name with no spaces. As an admin start the console (cmd) Input: NET USE LPT1: \\Computername\Printername /persistent:yes After that, DIR > LPT1: will print the directory to the printer Until here the Vista Laptop does the same as an XP one does! However, under XP, the DOS appplication works fine, under Vista it crashes with 'device not ready' There are many similar complaints to be read on various forums on the web. I haven't seen any solution yet, however. So, can you present us a solution to the problem ?? Kind regards, Guenter Predl "Hal Hostetler [MVP P/I]" wrote: Quote: > http://members.shaw.ca/bsanders/printfromdos.htm > Printing from DOS with Windows 2000 or XP > > This works for Vista, too. > > Hal > -- > Hal Hostetler, CPBE -- hhh@xxxxxx > Senior Engineer/MIS -- MS MVP-Print/Imaging -- WA7BGX > http://www.kvoa.com -- "When News breaks, we fix it!" > KVOA Television, Tucson, AZ. NBC Channel 4 > Live at Hot Licks - www.badnewsbluesband.com > > "Ron b." <Ronb@xxxxxx> wrote in message > news:9B30A3F1-25A1-4467-B33A-B0ED08800185@xxxxxx Quote: > > does anyone know how to print to a usb printer in dos from dos prompt. no > > lpt1 port Parallel port printer. > > |
| Vista Can't Print to Win2K shared printer-Test Print disappears fr | Vista networking & sharing | |||
| Deleted Printer but icon still there & printer wont auto install & wont print | Vista installation & setup | |||
| Deleted Printer but icon still there & printer wont auto install & wont print | Vista print fax & scan | |||
| Deleted Printer but icon still there & printer wont auto install & wont print | Vista performance & maintenance | |||
| Re: Print Shop won't print using laser printer | Vista print fax & scan | |||
