br> br> |
| | Thread Tools | Display Modes |
| Guest | wireless and can't print I am using Vista. I have wireless connection, yet my printer will no longer print from my laptop. What do I need to do to have the printer print from my laptop using wireless connection? My laptop shows I am not connected to the wireless service, yet I am able to search the internet, which is obvious since I am at this site. I wonder if this is why the laptop and printer are not communicating? |
| | #2 (permalink) | ||||||||||||
| Guest | Re: wireless and can't print bhoward wrote:
wireless network. This would explain why the resources on your *own* Local Area Network aren't available. This can happen if you didn't change your own wireless network name (SSID) to something memorable but just left it at the default, such as "Linksys". Lots of people do this so it is completely possible to have two "Linksys" wireless networks in the same area. If you think this could be the case, you should change your wireless settings since you aren't set up securely. Here's my general wireless setup information: ***** Have a computer connected to the router with an ethernet cable. Examples given are for a Linksys router. Refer to your router manual or the router mftr.'s website for default settings if you don't have a Linksys. Open a browser such as Internet Explorer or Firefox and in the addressbar type: http://192.168.1.1 [enter] (this is the router's default IP address, which varies from router to router so check your manual) This will bring you to router's login screen. The default username is left blank and the Linksys default password is "admin" without the quotes. Enter that information. You are now in the router's configuration utility. Your configuration utility may differ slightly from mine. Click on the Administration link at the top of the page. Enter your new password. WRITE IT DOWN SOMEWHERE YOU WILL NOT LOSE IT. Re-enter the password to confirm it and click the Save Settings button at the bottom of the page. The router will restart and present you with the login box again. Leave the username blank and put in your new password to get back into the configuration utility. Now click on the Wireless link at the top of the page. Change the Wireless Network Name (SSID) from the default to something you will recognize. I suggest that my clients not use their family name as the SSID. For example, you might wish to name your wireless network "CastleAnthrax" or the like. ;-) Click the Save Settings and when you get the prompt that your changes were successful, click on the Wireless Security link which is right next to the Basic Wireless Settings link (where you changed your SSID). If you have a newish computer, you will be able to set the Security Mode to WPA2-Personal. Do that and enter a passphrase. The passphrase is what you will enter on any computers that are allowed to connect to the wireless network. WRITE IT DOWN SOMEWHERE YOU WILL NOT LOSE IT. At this point, your router is configured and if the computer you were using to configure the router is normally going to connect wirelessly, disconnect the ethernet cable and the computer's wireless feature should see your new network. Enter the passphrase you created to join the network and start surfing. **** If this doesn't fit your situation, post back with details of your connection, your router, what changed between the time things worked and the time they didn't, etc. Malke -- MS-MVP Elephant Boy Computers - Don't Panic! FAQ - http://www.elephantboycomputers.com/#FAQ | ||||||||||||
My System Specs![]() | |||||||||||||
| | #3 (permalink) | ||||||||||||||||||||||||
| Guest | Re: wireless and can't print Thank you for the information. Before I start trying to fix this problem, I thought I woud let you know Belkin is my wireless router. Nothing has changed since it was installed. The Geek Squad from Best Buy set vverything up. I do remember one other time when the printer would not print from my laptop. Best Buy sent someone out and fixed whatever was wrong, or blocking the signal to the printer. Best Buy will charge me if they come out again. I would like to try and fix this myself. At times, a message will come up about needing administrator's permission. I am the administrator. I am very frustrated not being able to print, when I have not changed anything. "Malke" wrote:
My System Specs![]() | |||||||||||||||||||||||||
| | #4 (permalink) | ||||||||||||
set you up. The instructions I gave you are general instructions and are applicable whether you have a Linksys, Netgear, Belkin, etc. You need to read your Belkin manual or go to Belkin's website if you didn't get a manual. Unfortunately, I can't see your network setup from here and without any actual error messages (quoted, not approximated), knowledge of security software installed, etc. I can't guess at your problem. I applaud your desire to fix this yourself but if you want troubleshooting help you're going to need to provide exact details. 1. Does the problem occur on all devices connecting wirelessly or just one? Perhaps there is only one, your laptop. 2. Enter your router's configuration utility as previously described and make a note of what encryption you are using and the passphrase (encryption key). Make sure you aren't using MAC address filtering. Make sure you have changed your SSID, etc. from the default as I previously described. 3. On the computer(s) with the problem, what antivirus/security/firewall software is installed? 4. Check your printer's IP address and subnet and make a note of it. Refer to your printer manual (or printer mftr.'s website) for how to do this. 5. On the problem computer(s), look at the IP configuration by: Start>Search>type:cmd When cmd appears in the Results above, right-click and choose "run as Administrator". The command line box will appear. At the command prompt type: ipconfig /all [enter] Make sure the IP address is in the same subnet as the router; i.e. if your router is 192.168.2.1, all devices on the Local Area Network need to be 192.168.2.xxx (where "xxx" represents some numbers). Malke -- MS-MVP Elephant Boy Computers - Don't Panic! FAQ - http://www.elephantboycomputers.com/#FAQ | ||||||||||||
| Display Modes | |
| Can't print from my wireless laptop | Scallo42 | Network & Internet | 3 | 04-08-2008 10:04 AM |
| Print copies with wireless print server. | Patrick C | Vista print fax & scan | 0 | 01-05-2008 06:11 AM |
| Wireless Print Server | ~andrew | Vista networking & sharing | 0 | 02-09-2007 02:13 AM |
| can't print with a wireless print server | Killallspammers | Vista General | 2 | 01-28-2007 11:27 AM |
| Wireless print server | Killallspammers | Vista networking & sharing | 1 | 01-28-2007 11:25 AM |
