| vista 64-bit ulimate sp1 | error 1075 printer spooler is not running hi all i am here to say this is my fault but as usual i f*** up i uninstalled my printer and all its' drivers rebooted and proceed to delete file folders and anything that was associated with my hp office jet j5750 as well as going to regedit and deleting the files there NOW my printer spooler is not running at all when i go ti re install the printer it states printer spooler not running or ERROR 1075: the dependency service does not exist or has been marked for deletion this is also happens when i go into services.msc. any help here would be great |
| Windows 7 RC x64 Vista HP x86 | Re: error 1075 printer spooler is not running This is a solution from Technet have not tried it but ypu're welcome to have a go DON'T FORGET to backup thr registry branch before you do anything Click on Vista (Start) button, and type Regedit.exe in search bar Navigate to the following branch HKEY_LOCAL_MACHINE \ SYSTEM \ CurrentControlSet \ Services \ Spooler In the right-pane, double-click the DependOnService value Delete the existing data, and then type RPCSS Close Regedit.exe Restart the computer. This should resolve the issue. |
| vista 64-bit ulimate sp1 | Re: error 1075 printer spooler is not running thanks when i went there it had RPCSS http i deleted http then rebooted i will let you know |
| vista 64-bit ulimate sp1 | Re: error 1075 printer spooler is not running it did work that is on the money all the best |
| | Re: error 1075 printer spooler is not running I have tried everything to get the spooler running again. I have made sure the RPC and spooler services were both running. I have restarted and removed http from the DependOnService value. I can see my printer now along with the other default ones. But I can't add or remove printers. error message is: operation can't be complete, spooler is not running. I can get the spooler running for about 5 seconds but that's about it. Any ideas beside the ones below...? I have a new Gateway FX Vista/64. printer is an HP LaserJet 1018. An help would be greatly appreciated. Brian -- paapb ------------------------------------------------------------------------ paapb's Profile: http://forums.techarena.in/members/paapb.htm View this thread: http://forums.techarena.in/vista-print-fax/1015618.htm http://forums.techarena.in |
| | #6 (permalink) |
| | Re: error 1075 printer spooler is not running in an elevated command window, do you still get the 1075 error when starting the spooler? net start spooler ? -- Alan Morris Windows Printing Team Search the Microsoft Knowledge Base here: http://support.microsoft.com/search/?adv=1 This posting is provided "AS IS" with no warranties, and confers no rights. "paapb" <paapb.3n0nvb@xxxxxx> wrote in message news aapb.3n0nvb@xxxxxxQuote: > > I have tried everything to get the spooler running again. > I have made sure the RPC and spooler services were both running. I have > restarted and removed http from the DependOnService value. > I can see my printer now along with the other default ones. > But I can't add or remove printers. error message is: operation can't > be complete, spooler is not running. I can get the spooler running for > about 5 seconds but that's about it. > Any ideas beside the ones below...? > > I have a new Gateway FX Vista/64. > printer is an HP LaserJet 1018. > > An help would be greatly appreciated. > > Brian > > > -- > paapb > ------------------------------------------------------------------------ > paapb's Profile: http://forums.techarena.in/members/paapb.htm > View this thread: http://forums.techarena.in/vista-print-fax/1015618.htm > > http://forums.techarena.in > |
| HP Printer, spooler service not running | Vista print fax & scan | |||
| spooler error gone - now can't get printer to work | Vista print fax & scan | |||
| I NEED help with Printer Spooler Error | Drivers | |||
| printer spooler not running | Vista print fax & scan | |||
| Printer spooler error 1068 | Drivers | |||
