Go Back   Vista Forums > Vista Newsgroups > Vista print fax & scan
Vista - Remote printing using HP P1505
Old 08-07-2008   #1 (permalink)
huffnpuff
Trying to print from remote computer on my local printer. I have Windows
Vista Home Premium 64 bit system installed on my HP home computer. The
remote computer is using Windows XP. I installed drivers as per IT
instructions and printer worked at that time. Shut down my computer and
when I went back in to remote was again unable to print. Any help would be
appreciated.
Old 09-22-2009   #2 (permalink)
64
Re: Remote printing using HP P1505
I have exactly the same issue - essentially you can the test page and that's it - HP HELP claim it is because the reare more than 5 users... I think it is because the Vista64 and 1505 drivers clash and the 1505 'forgets' where the file came from. I bought a 1505n to solve the problem - no good - works fine from any XP (ie more than 5 computers on the network) prints the test page only from Vista 64. Anybody have a work around?
HP P1505 Not Responding Vista print fax & scan
Remote printing with VISTA Vista networking & sharing
Remote Desktop Printing Vista networking & sharing
Remote Printing and Vista - HELP!!!! Vista print fax & scan
Remote Desktop Printing Vista General
