| Vista Home Premium 32bit | Hp LaserJet 3050 scanner wont work....help!!!! all functions work perfectly, printing, faxing, and copying. whenever i try to scan this message pops up: " There is no TWAIN-compliant device installed. please install one and try again" i don't know what to do. plrease help |
| | Re: Hp LaserJet 3050 scanner wont work....help!!!! The message usually means that windows does not see the scanner, or the scanner uses an OEM driver instead of built in windows support. There may also be a problem that is caused by the scanner driver not being installed. A possibility is to use the trial version of Viewscan from Hamrick Software to see if the scanner works with it. "finger" <guest@xxxxxx-email.com> wrote in message news:7aa36f0ba7a72bd24f1a9c89790d1e00@xxxxxx-gateway.com... Quote: > > all functions work perfectly, printing, faxing, and copying. > > whenever i try to scan this message pops up: " There is no > TWAIN-compliant device installed. please install one and try again" > > > i don't know what to do. > > plrease help > > > -- > finger |
| | Re: Hp LaserJet 3050 scanner wont work....help!!!! On Aug 17, 10:01*pm, finger <gu...@xxxxxx-email.com> wrote: Quote: > all functions work perfectly, printing, faxing, and copying. > > whenever i try to scan this message pops up: " There is no > TWAIN-compliant device installed. please install one and try again" > > i don't know what to do. > > plrease help > > -- > finger version have you got? |
| | Re: Hp LaserJet 3050 scanner wont work....help!!!! In article <7aa36f0ba7a72bd24f1a9c89790d1e00@xxxxxx-gateway.com>, Finger wrote: Quote: > all functions work perfectly, printing, faxing, and copying. > Windows Quote: > whenever i try to scan this message pops up: " There is no > TWAIN-compliant device installed. please install one and try again" You have not said what version of Windows you are using -- VISTA one assumes but which version? Home Basic, Home Premium, Business ... or Ultimate? This is important because the Home versions do not contain the scanning and faxing utility of the other versions of VISTA. Please give answers to these questions since I don't understand how you can fax or copy without using the scanner yet you say you get an error message when scanning. Or are you successfully scanning and getting the error message? Hugh Windows XP Service Pack 3 build 2600 VAOS Off Line Reader 6.3 build 1 |
| | Re: Hp LaserJet 3050 scanner wont work....help!!!! Hi.... I am experiencing the same thing. Only scanner that doesn't work after I install the newest service pack from Vista. Mine is Home basic. Before this morning update everything was working just fine ![]() "huwyngr" wrote: Quote: > In article <7aa36f0ba7a72bd24f1a9c89790d1e00@xxxxxx-gateway.com>, Finger > wrote: > Quote: > > all functions work perfectly, printing, faxing, and copying. > > > Do you mean if you push buttons on the device or if you use controls in > Windows > Quote: > > whenever i try to scan this message pops up: " There is no > > TWAIN-compliant device installed. please install one and try again" > This, for me, has meant that Windows is not seeing my scanner. > > You have not said what version of Windows you are using -- VISTA one > assumes but which version? Home Basic, Home Premium, Business ... or > Ultimate? > > This is important because the Home versions do not contain the scanning > and faxing utility of the other versions of VISTA. > > Please give answers to these questions since I don't understand how you > can fax or copy without using the scanner yet you say you get an error > message when scanning. Or are you successfully scanning and getting the > error message? > > > Hugh > > Windows XP Service Pack 3 build 2600 VAOS Off Line Reader 6.3 build 1 > > |
| | #6 (permalink) |
| | RE: Hp LaserJet 3050 scanner wont work....help!!!! "finger" wrote: Quote: > > all functions work perfectly, printing, faxing, and copying. > > whenever i try to scan this message pops up: " There is no > TWAIN-compliant device installed. please install one and try again" > > > i don't know what to do. > > plrease help > > > -- > finger > Did you ever get your scanner to work? How? Mine has the same problem and asks for a CD to install it. We don't have a CD. |
| | #7 (permalink) |
| | Re: Hp LaserJet 3050 scanner wont work....help!!!! You can download the software from HP.com -- Cari (MS-MVP) Printing & Imaging www.coribright.com/windows "kathyt" <kathyt@xxxxxx> wrote in message news:007CC60E-0263-4003-90A9-C0F7C10045DB@xxxxxx Quote: > > > "finger" wrote: > Quote: >> >> all functions work perfectly, printing, faxing, and copying. >> >> whenever i try to scan this message pops up: " There is no >> TWAIN-compliant device installed. please install one and try again" >> >> >> i don't know what to do. >> >> plrease help >> >> >> -- >> finger >> Did you ever get your scanner to work? How? Mine has the same problem >> and asks for a CD to install it. We don't have a CD. |
| Hp LaserJet 3050 scanner wont work....help!!!! | Vista hardware & devices | |||
| Re: HP LaserJet 3050 as shared printer | Vista print fax & scan | |||
| HP LaserJet 3050 Not Availalbe on Server 2003 from Vista | Vista General | |||
| Scanning with Vista and HP LaserJet 3050 | Vista installation & setup | |||
