| Welcome to Windows Vista Forums. Our forum is dedicated to helping you find solutions with any problems, errors or issues you are experiencing with Windows Vista. The Vista forum also covers news and updates and has an extensive Vista tutorial section that covers a wide range of tips and tricks. |
| | LinkBack | Thread Tools | Display Modes |
| Member | Printer driver neededfor HP Photosmart printer...help I have a HP photosmart 1218 and have just brought a new rig which has a dual boot config with Vista64 and Xp Pro64. I have managed to get the printer to install in XP but trying the same method in Vista doesn't work.. can anyone help? I installed it in XP Pro64 by downloading the XP64 bit driver for a deskjet 970cse and then simply installing it ![]() HP themselves suggested just setting the printer up manually in Vista as a deskjet 970cse.. this gave me the idea for the above trick. But when i tried this the test page came out garbled where as in XP the test page printed fine. I know the printer is getting old but it works perfectly well and i'm loathed to bin it . So is there anyone out there who can point me in the direction of any other drivers i could use other than the official xp 32 bit software driver on the HP website which doesn't work. Thanx in advance. Steve. |
| | #2 (permalink) | ||||||||||||
| Guest | Re: Printer driver neededfor HP Photosmart printer...help "stox" <guest@xxxxxx-email.com> wrote in message news:9d856cd15fa073a7d6389bb0d6978200@xxxxxx-gateway.com...
Use Add Printer, add it as LPT1: using the built-in driver in Vista nd then change later to the USB port if needed. Regards, Bob Headrick, MS MVP Printing/Imaging | ||||||||||||
My System Specs![]() | |||||||||||||
| Member | Re: Printer driver neededfor HP Photosmart printer...help Thanx Bob, i will give that a go. I will let you know how i get on. |
| Member | Re: Printer driver needed for HP Photosmart printer...help Thanx again Bob, It worked |
| | #5 (permalink) | ||||||||||||
| Guest | RE: Printer driver neededfor HP Photosmart printer...help "stox" wrote:
| Display Modes | |
| photosmart hp printer | cc47 | Vista networking & sharing | 9 | 03-06-2008 01:36 PM |
| Old Hp printer deskjet 722C pls help me install a printer driver | Del | .NET General | 1 | 03-06-2008 07:42 AM |
| Can I use a shared printer on XP with a local printer driver on Vista | Alex Ferenstein | Vista General | 2 | 11-08-2007 05:17 AM |
| HP Printer PhotoSmart 8230 | Cindy | Vista print fax & scan | 4 | 04-16-2007 10:29 AM |
| HP Photosmart Printer C-5180 | =?Utf-8?B?Q2hyaXM=?= | Vista hardware & devices | 8 | 10-01-2006 07:17 PM |
