Go Back   Vista Forums > Vista Newsgroups > Vista print fax & scan
Vista - Lexmark 4500 series printer solution
Old 09-23-2008   #1 (permalink)
Vista Home Premium
Hi to all new Lemark installations. I just want to share my experience. I purchased a X4560 Wireless Printer, great printer for my needs. There was a sticker on the box that said...."10 minutes to install" which was true if you hook up a usb connector...but I wanted a wireless hook-up....well it took me a phone call to Lexmark Support (overseas..no help), a lot of cussing, trial and error and a 5 minute call to my DSL provider for a total of 4 hours. Firstly follow the CD install instructions carefully, make sure that the SSID number on printer and your computer are same and make sure your WEP number is correct. The WEP is the number on your wireless router. Guess what....I kept installing my WEP printed on the Router...wrong!!!! For some unknown reason the WEP number was entered as my home phone number when the router was installed. The DSL rep guided me to the Router's Web Site/Wireless Security Section to verify the WEP number and ..Wah La...there it was, I installed the corrected WEP and it fired right up.
Hope this helps
cannot install Lexmark 3500 - 4500 series printer on Vista Ultimate Vista print fax & scan
Printer - Lexmark Z500-600 series Vista General
my lexmark 1200 series printer and scanner does not work! Vista print fax & scan
Lexmark Drivers for Lexmark 2300 series printers Vista General
Printer Driver Lexmark 810 Series Vista print fax & scan
