Go Back   Vista Forums > Vista Newsgroups > Vista print fax & scan
Vista - Epson LQ-590 usb driver does not work
Old 09-29-2008   #1 (permalink)
Charmaine
My print job seems to get stuck at the print queue and hangs my pc when I try
to print something. I'm running on Vista Business edition.
No error message from the printer. I cannot delete the job from the print
queue. I will have to re-start my printer/remove my usb cable for it to work.
The worst case is that it hangs my pc and I will have to do a reboot.
I've installed the default usb driver from Windows. Any idea what went wrong?
Old 09-30-2008   #2 (permalink)
Cari \(MS-MVP\)
Re: Epson LQ-590 usb driver does not work
The Inbox driver (the one included in Vista but provided by Epson) seems to
be all there is. Is the printer USB or do you have an LPT to USB adapter
cable?
Cari (MS-MVP) Printing & Imaging
www.coribright.com/windows
"Charmaine" <Charmaine@xxxxxx> wrote in message
news:BC008879-CBCA-4CD6-890F-8ACFE1513DCF@xxxxxx
> try
> work.
> wrong?
Old 10-02-2008   #3 (permalink)
Charmaine
It's a direct usb connection
> cable?
> > try
> > work.
> > wrong?
I need an Epson C88+ driver. Drivers
Epson DX8400 Driver help please... Drivers
Epson 1394.3 driver Vista hardware & devices
Epson Printer driver kills CD/DVD driver (MS Keep working PLEASE) Vista hardware & devices
Epson^Printers that work Vista hardware & devices
