Go Back   Vista Forums > Vista Newsgroups > Vista print fax & scan
Vista - Problems with Lexmark X4530 Wireless printer
Old 10-12-2008   #1 (permalink)
vistageek
I have a Lexmark X4530 Wireless printer and i am trying to connect it to my Hp laptop with Vista using my Netgear wireless router.It connects to the laptop but when i try to print something it just makes a folder in the C drive and makes a file in it and does not print anything.The printer works when i use the USB cable but when it does not when i try do it without the cable with wifi.DO i need any USB wireless adapter for it or something or do i need to fix something in the laptop.
Post Originated from http://www.VistaForums.com Vista Support Forums
Old 10-13-2008   #2 (permalink)
Alan Morris [MSFT]
Re: Problems with Lexmark X4530 Wireless printer
Determine the IP of the NIC on the printer, then create a Standard TCP/IP
port targeting the IP. Set the printer to the new port.
Alan Morris
Windows Printing Team
Search the Microsoft Knowledge Base here:
http://support.microsoft.com/search/?adv=1
<vistageek> wrote in message news:OzvDvfKLJHA.1012@xxxxxx
Problems printing from Vista to Lexmark z715 network printer on WinXP Vista print fax & scan
(Wireless network + USB Lexmark Printer) x Windows Vista = No Inte Vista networking & sharing
wireless printer problems Vista print fax & scan
Lexmark wireless printer Vista networking & sharing
Lexmark X4580 Wireless Printer Vista hardware & devices
