| | Problem installing Lexmark x4650 - error 0x000006be, Print Spooler, Add Printer I have had problems for the best part of a week now trying to install a brand new Lexmark x4650 printer onto my 6 month old Compaq Laptop running with Vista basic. I have tried other printers (HP and Dell) and have had similar problems. The printer seems to install fine (both using the provided disc and after downloading the latest drivers from the Lexmark website). However once installed I receive a message advising that some software for the drivers has not installed correctly. The printer is not then visible in the Control Panel. Also: 1) When trying to install (add) a new printer manually (before and after removing all previously installed software) an error message appears, telling that the spooler is not running (or similar) 2) When checking in the services.msc console, I can see that the spooler has stopped. 3) When starting the spooler, it seems to stark ok, but as soon as I try to (again) "add" a printing (using the appropriate button) - the spooler immediately crashes (stops) and the same error message occurs - spooler not started and/or - windows can't open add printer and/or - Operation could not be completed and/or - error 0x000006be - etc... 4) I have checked the dependencies for the spooler and they are all started and set to Automatic. I have spent hours going through this and other forums trying to find a solution. I have tried many that I have found but to no avail. I would be very grateful for any assistance anyone could provide - especially from Microsoft who (when I try to contact them) say they cannot help. I have spoken to Lexmark for an hour who said the printer and my laptop were working fine and it was a Vista problem. I have currently uninstalled all software and am back to square one! Please help. Many thanks in advance. AndyW -- AndyW68 |
| | Re: Problem installing Lexmark x4650 - error 0x000006be, Print Spooler, Add Printer Square one, does this maen the spooler is running at this time? Most spooler failures occur due to print driver corruption of the process memory. If the spooler is not running, verify that all the driver components are gone. http://members.shaw.ca/bsanders/CleanPrinterDrivers.htm -- Alan Morris Windows Printing Team Search the Microsoft Knowledge Base here: http://support.microsoft.com/search/?adv=1 This posting is provided "AS IS" with no warranties, and confers no rights. "AndyW68" <AndyW68.3390184@xxxxxx> wrote in message news:AndyW68.3390184@xxxxxx Quote: > > I have had problems for the best part of a week now trying to install a > brand new Lexmark x4650 printer onto my 6 month old Compaq Laptop > running with Vista basic. > > I have tried other printers (HP and Dell) and have had similar > problems. > > The printer seems to install fine (both using the provided disc and > after downloading the latest drivers from the Lexmark website). However > once installed I receive a message advising that some software for the > drivers has not installed correctly. The printer is not then visible in > the Control Panel. > > Also: > > 1) When trying to install (add) a new printer manually (before and > after removing all previously installed software) an error message > appears, > telling that the spooler is not running (or similar) > > 2) When checking in the services.msc console, > I can see that the spooler has stopped. > > 3) When starting the spooler, it seems to stark ok, > but as soon as I try to (again) "add" a printing (using the > appropriate button) > - the spooler immediately crashes (stops) > and the same error message occurs > - spooler not started and/or > - windows can't open add printer and/or > - Operation could not be completed and/or > - error 0x000006be > - etc... > > 4) I have checked the dependencies for the spooler and they are all > started and set to Automatic. > > I have spent hours going through this and other forums trying to find a > solution. I have tried many that I have found but to no avail. I would > be very grateful for any assistance anyone could provide - especially > from Microsoft who (when I try to contact them) say they cannot help. > > I have spoken to Lexmark for an hour who said the printer and my laptop > were working fine and it was a Vista problem. > > I have currently uninstalled all software and am back to square one! > > Please help. Many thanks in advance. > > AndyW > > > > > -- > AndyW68 |
| | Re: Problem installing Lexmark x4650 - error 0x000006be, Print Spooler, Add Printer Thanks for your response. When I look into services.msc the spooler is started and set to Automatic. However when I select file> server properties I receive a message saying 'Server properties cannot be viewed. The local printer spooler service is not running. Please restart the spooler or restart the machine' thanks Andyw68 'Alan Morris [MSFT Wrote: Quote: > ;732181']Square one, does this maen the spooler is running at this time? > Most > spooler failures occur due to print driver corruption of the process > memory. > > If the spooler is not running, verify that all the driver components > are > gone. > > 'Bruce's Printing Pages' > (http://members.shaw.ca/bsanders/CleanPrinterDrivers.htm) > > -- > Alan Morris > Windows Printing Team > Search the Microsoft Knowledge Base he > 'Advanced Search' (http://support.microsoft.com/search/?adv=1) > > This posting is provided "AS IS" with no warranties, and confers no > rights. > > "AndyW68" AndyW68.3390184@xxxxxx wrote in message > news:AndyW68.3390184@xxxxxx- > > I have had problems for the best part of a week now trying to install > a > brand new Lexmark x4650 printer onto my 6 month old Compaq Laptop > running with Vista basic. > > I have tried other printers (HP and Dell) and have had similar > problems. > > The printer seems to install fine (both using the provided disc and > after downloading the latest drivers from the Lexmark website). > However > once installed I receive a message advising that some software for > the > drivers has not installed correctly. The printer is not then visible > in > the Control Panel. > > Also: > > 1) When trying to install (add) a new printer manually (before and > after removing all previously installed software) an error message > appears, > telling that the spooler is not running (or similar) > > 2) When checking in the services.msc console, > I can see that the spooler has stopped. > > 3) When starting the spooler, it seems to stark ok, > but as soon as I try to (again) "add" a printing (using the > appropriate button) > - the spooler immediately crashes (stops) > and the same error message occurs > - spooler not started and/or > - windows can't open add printer and/or > - Operation could not be completed and/or > - error 0x000006be > - etc... > > 4) I have checked the dependencies for the spooler and they are all > started and set to Automatic. > > I have spent hours going through this and other forums trying to find > a > solution. I have tried many that I have found but to no avail. I > would > be very grateful for any assistance anyone could provide - especially > from Microsoft who (when I try to contact them) say they cannot help. > > I have spoken to Lexmark for an hour who said the printer and my > laptop > were working fine and it was a Vista problem. > > I have currently uninstalled all software and am back to square one! > > Please help. Many thanks in advance. > > AndyW > > > > > -- > AndyW68 - -- AndyW68 |
| | Re: Problem installing Lexmark x4650 - error 0x000006be, Print Spooler, Add Printer the spooler is crashing. This is typically caused by print drivers corrupting the memory in the spooler process Check the registry for the print drivers that are installed on the system and follow Bruce's instructions. -- Alan Morris Windows Printing Team Search the Microsoft Knowledge Base here: http://support.microsoft.com/search/?adv=1 This posting is provided "AS IS" with no warranties, and confers no rights. "AndyW68" <AndyW68.33b6c42@xxxxxx> wrote in message news:AndyW68.33b6c42@xxxxxx Quote: > > Thanks for your response. When I look into services.msc the spooler is > started and set to Automatic. However when I select file> server > properties I receive a message saying 'Server properties cannot be > viewed. The local printer spooler service is not running. Please > restart the spooler or restart the machine' > > thanks > Andyw68 > > 'Alan Morris [MSFT Wrote: Quote: >> ;732181']Square one, does this maen the spooler is running at this time? >> Most >> spooler failures occur due to print driver corruption of the process >> memory. >> >> If the spooler is not running, verify that all the driver components >> are >> gone. >> >> 'Bruce's Printing Pages' >> (http://members.shaw.ca/bsanders/CleanPrinterDrivers.htm) >> >> -- >> Alan Morris >> Windows Printing Team >> Search the Microsoft Knowledge Base he >> 'Advanced Search' (http://support.microsoft.com/search/?adv=1) >> >> This posting is provided "AS IS" with no warranties, and confers no >> rights. >> >> "AndyW68" AndyW68.3390184@xxxxxx wrote in message >> news:AndyW68.3390184@xxxxxx- >> >> I have had problems for the best part of a week now trying to install >> a >> brand new Lexmark x4650 printer onto my 6 month old Compaq Laptop >> running with Vista basic. >> >> I have tried other printers (HP and Dell) and have had similar >> problems. >> >> The printer seems to install fine (both using the provided disc and >> after downloading the latest drivers from the Lexmark website). >> However >> once installed I receive a message advising that some software for >> the >> drivers has not installed correctly. The printer is not then visible >> in >> the Control Panel. >> >> Also: >> >> 1) When trying to install (add) a new printer manually (before and >> after removing all previously installed software) an error message >> appears, >> telling that the spooler is not running (or similar) >> >> 2) When checking in the services.msc console, >> I can see that the spooler has stopped. >> >> 3) When starting the spooler, it seems to stark ok, >> but as soon as I try to (again) "add" a printing (using the >> appropriate button) >> - the spooler immediately crashes (stops) >> and the same error message occurs >> - spooler not started and/or >> - windows can't open add printer and/or >> - Operation could not be completed and/or >> - error 0x000006be >> - etc... >> >> 4) I have checked the dependencies for the spooler and they are all >> started and set to Automatic. >> >> I have spent hours going through this and other forums trying to find >> a >> solution. I have tried many that I have found but to no avail. I >> would >> be very grateful for any assistance anyone could provide - especially >> from Microsoft who (when I try to contact them) say they cannot help. >> >> I have spoken to Lexmark for an hour who said the printer and my >> laptop >> were working fine and it was a Vista problem. >> >> I have currently uninstalled all software and am back to square one! >> >> Please help. Many thanks in advance. >> >> AndyW >> >> >> >> >> -- >> AndyW68 - > > > > -- > AndyW68 |
| | Re: Problem installing Lexmark x4650 - error 0x000006be, Print Spooler, Add Printer Hi. I have followed Bruce’s guide to the letter and manually removed as much printer related files as I can see. I was unable to use the cleanspl.exe as it does not work with NT6.0 (only 4.0 and 5.0). However this has not worked. When I reinstalled the Lexmark printer using the provided disc, the install completes successfully but the printer does not print and no printer is visible in control panel. When the USB cable is connected (both during and after the install process) Windows searches for drivers and provides the following message in a Found New Hardware’ box: ‘Windows encountered a problem installing the driver software for your device. Windows found driver software for your device but encountered an error while attempting to install it. One of the installers for this device cannot perform the installation at this time’ Selecting ‘Add Printer’ manually produces the messages below (depending on whether the print spooler is running at the time): Error 1067 – could not start the print spooler service – terminated unexpectedly Unable to add printer spooler service is not working Error 0x000006be There were however some files that I was unsure as to whether I should delete or not. These were in folder %systemroot%\system32\spool\drivers\w32x86. A screen dump of these in the attached document. Thanks 'Alan Morris [MSFT Wrote: Quote: > ;733327']the spooler is crashing. This is typically caused by print > drivers > corrupting the memory in the spooler process > > Check the registry for the print drivers that are installed on the > system > and follow Bruce's instructions. > > -- > Alan Morris > Windows Printing Team > Search the Microsoft Knowledge Base he > 'Advanced Search' (http://support.microsoft.com/search/?adv=1) -- AndyW68 |
| | #6 (permalink) |
| | Re: Problem installing Lexmark x4650 - error 0x000006be, Print Spooler, Add Printer The PnP service can't install a print driver when the spooler is not running. is there a WER (Windows Error Report) file for the failure? %systemroot%\programdata\Microsoft\Windows\WER\ReportQueue\Report[#####] if you see spooler.xml and the *.tmp.hmp then you have a full memory dump of the spooler service as it failed Report.wer spooler.xml SpoolerETW.etl WERAF80.tmp.version.txt WERAF81.tmp.appcompat.txt WERAFA2.tmp.hdmp WERC42C.tmp.mdmp -- Alan Morris Windows Printing Team Search the Microsoft Knowledge Base here: http://support.microsoft.com/search/?adv=1 This posting is provided "AS IS" with no warranties, and confers no rights. "AndyW68" <AndyW68.33cf600@xxxxxx> wrote in message news:AndyW68.33cf600@xxxxxx Quote: > > Hi. > > I have followed Bruce's guide to the letter and manually removed as > much printer related files as I can see. I was unable to use the > cleanspl.exe as it does not work with NT6.0 (only 4.0 and 5.0). > > However this has not worked. > > When I reinstalled the Lexmark printer using the provided disc, the > install completes successfully but the printer does not print and no > printer is visible in control panel. > > When the USB cable is connected (both during and after the install > process) Windows searches for drivers and provides the following > message in a Found New Hardware' box: > > 'Windows encountered a problem installing the driver software for your > device. Windows found driver software for your device but encountered > an error while attempting to install it. One of the installers for this > device cannot perform the installation at this time' > > Selecting 'Add Printer' manually produces the messages below (depending > on whether the print spooler is running at the time): > > Error 1067 - could not start the print spooler service - terminated > unexpectedly > > Unable to add printer spooler service is not working > > Error 0x000006be > > There were however some files that I was unsure as to whether I should > delete or not. These were in folder > %systemroot%\system32\spool\drivers\w32x86. A screen dump of these in > the attached document. > > Thanks > > 'Alan Morris [MSFT Wrote: Quote: >> ;733327']the spooler is crashing. This is typically caused by print >> drivers >> corrupting the memory in the spooler process >> >> Check the registry for the print drivers that are installed on the >> system >> and follow Bruce's instructions. >> >> -- >> Alan Morris >> Windows Printing Team >> Search the Microsoft Knowledge Base he >> 'Advanced Search' (http://support.microsoft.com/search/?adv=1) > > > > -- > AndyW68 |
| | #7 (permalink) |
| | Re: Problem installing Lexmark x4650 - error 0x000006be, Print Spooler, Add Printer I can see no WER in the folder ReportQueue but there are 5 in the Report Archive (also in the WER folder you mention). However could you advise which program I should use to open them? I receive the message 'Windows cannot open this file - please select from a list' when I tried to. Apologies for my lack of knowledge on this. Thanks for you help. 'Alan Morris [MSFT Wrote: Quote: > ;734104']The PnP service can't install a print driver when the spooler > is not > running. > > is there a WER (Windows Error Report) file for the failure? > > %systemroot%\programdata\Microsoft\Windows\WER\ReportQueue\Report[#####] > > if you see spooler.xml and the *.tmp.hmp then you have a full memory > dump of > the spooler service as it failed > > Report.wer > spooler.xml > SpoolerETW.etl > WERAF80.tmp.version.txt > WERAF81.tmp.appcompat.txt > WERAFA2.tmp.hdmp > WERC42C.tmp.mdmp > -- > Alan Morris > Windows Printing Team > Search the Microsoft Knowledge Base he > 'Advanced Search' (http://support.microsoft.com/search/?adv=1) -- AndyW68 |
| CAN'T: Open Control Panel, Restore, Printer, 'print spooler' error... | General Discussion | |||
| Can't scan over wireless network with Lexmark x4650 | Vista print fax & scan | |||
| printer / print spooler problem | Drivers | |||
| Printer Installation Error 0x000006be | Vista print fax & scan | |||
| Lexmark Printer / Error problem communicating with printer | Vista print fax & scan | |||
