| | How I fixed my Vista Print Spooler Problems I have been a long time user of Windows XP SP2. I had recently putchased Vista Ultimate with the intent to upgrade my XP system. The principal problem was all attempts to add a printer resulted in errors stemming from the Print Spooler Service. Before I begin let me preface my environment: Intel 2.8 GHz machine with 2 GB RAM and ATI 1300 video. XP SP2 as I mentioned. I have used over the years the following imaging devices: a. HP Color LaserJet 4650 b. HP 8150 AIO Injet/Scanner/Fax c. HP 9100 Digital sender I should note that the digital sender has long since been removed. The 8150 is seldom used. Both of these devices had left a long residue of drivers and services on my XP box. The Laserjet only used a PCL6 driver. ------ The Vista Experience --------- Now begins my 14 hours of debug joy. The Vista install went fairly smoothly. The Windows Compatibility check noted some issues with Symmantec AntiVirus, ATI veido, Sigmatel Audio, Windows MGR 5.1, and the Common Client. Nothing seemed out of hte ordinary so I went with an upgrade install of Vista Ultimate. The installation took about 3 hours. When complete I verified that video, networking, my critical applications, and device worked. Most did, except for the DVD drive. There is a BLOG dedicated to that issue. The main problem was trying to add a printer. All attempts to add a printer resulted in a pop up showing: "windows can't open add printer. the local print spooler is not running" If I manually restarted the Print Spooler service and quickly add a printer in the Control Panel dialogue I got a different error: "0x000006be error" So began the Google searches for help. 1. I attempted to restart the spooler services as noted on many blogs: Problem installing Lexmark x4650 - error 0x000006be, Print Spooler, Add Printer 1. I attempted to manually clean all my drivers and registry changes as noted here: http://members.shaw.ca/bsanders/CleanPrinterDrivers.htm This did not help 2. I traversed HP's site and found this tidbit: http://h10025.www1.hp.com/ewfrf/wc/d...reg_R1002_USEN No luck yet. 3. I traversed MS support and found this KB: http://support.microsoft.com/kb/324757 I did go to C:/windows/system32/spool/ I deleted all drivers - residue from the XP builds. The PRINTERS directory was empty (obviously no prointers were every installed) I deleted all printprocs. Many blogs indicated this successfully worked for different users. However, this did not resolve the problem. 4. I reinstalled Vista No luck there either 5. I tried installing a Vista CD installation of the Laserjet 4700 thinking a full Cd isntall might work : No luck 6. I tried downloading the PrintFlush-1.3 utility to clean the Spooler settings and queues. No luck 7. I downloaded the Print Spooler Fix wizard. While this didn't work it did clue me into some registry settings that were dangling. I deleted them. Still no luck 8. Finally I went to C:/windows/system32 and added columns to the directory listing to indicate company names. I deleted all HP drivers I could find. I have to say the HP AIO 8150 left a shotgun of driver residue. ----------------------------------------- The fix -------------------------------- Now begins some deeper debugging and resolution. As you see I have stripped my registry settings, drivers, monitors, and whatnot. You can assume I have no print drivers at this point. 1. I went to Device Manager and reviewed the logs. Under Event Views - Quote: > Windows Logs -> Application. I noticed failures related to the "The print spooler cannot start because the PrinterBusEnumerator could not start. Error code 0x80070006. This can occur because of system instability or a lack of system resources." 2. I searched Google and found a relationship between PrinterBusEnumerator and the UMBus (User Mode Bus). 3. I went to Device Manager again and clicked on View -> Show Hidden Devices. Selected System Devices. And Uninstalled both the UMBus Enumerator as well as teh UMBus Root Bus Enumerator. 4. Rebooted. 5. Went to Control Panel. Selected Add Hardware. 6. Selected Install the Hardware Manually. 7. Clicked on the first selection: "Show All Devices" 8. Added back bot the Microsoft UMBus Enumerator and the UMBus Root Bus Enumerator. 9. Rebooted. 10. Went to add printer. And could then add back my Color Laserjet 4600. 11. Printed a test page and application document as a test. Hope that might help someone in the future. |
| | RE: How I fixed my Vista Print Spooler Problems Many thanks for a detailed clear explanation. I am trying to solve "Spooler Subsystem App problems reinstalling Lexmark". Can you look at my post and suggest any ideas? I have done up to your step 3. Am thinking of completely going back to factory setup of Vista computer but this will be painful and timeconsuming and I'm scared it might not solve the problem. How did you do the Event Views? How did you find the PrintFlush utility and Print Spooler Fix Wizard? "perrylea@xxxxxx" wrote: Quote: > I have been a long time user of Windows XP SP2. I had recently > putchased Vista Ultimate with the intent to upgrade my XP system. > > The principal problem was all attempts to add a printer resulted in > errors stemming from the Print Spooler Service. > > Before I begin let me preface my environment: > > Intel 2.8 GHz machine with 2 GB RAM and ATI 1300 video. XP SP2 as I > mentioned. > I have used over the years the following imaging devices: > > a. HP Color LaserJet 4650 > b. HP 8150 AIO Injet/Scanner/Fax > c. HP 9100 Digital sender > > I should note that the digital sender has long since been removed. > The 8150 is seldom used. Both of these devices had left a long > residue of drivers and services on my XP box. The Laserjet only used > a PCL6 driver. > > > ------ The Vista Experience --------- > Now begins my 14 hours of debug joy. The Vista install went fairly > smoothly. The Windows Compatibility check noted some issues with > Symmantec AntiVirus, ATI veido, Sigmatel Audio, Windows MGR 5.1, and > the Common Client. Nothing seemed out of hte ordinary so I went > with an upgrade install of Vista Ultimate. > > The installation took about 3 hours. > > When complete I verified that video, networking, my critical > applications, and device worked. Most did, except for the DVD drive. > There is a BLOG dedicated to that issue. > > The main problem was trying to add a printer. > > > > All attempts to add a printer resulted in a pop up showing: > "windows can't open add printer. the local print spooler is not > running" > > If I manually restarted the Print Spooler service and quickly add a > printer in the Control Panel dialogue I got a different error: > "0x000006be error" > > > So began the Google searches for help. > > 1. I attempted to restart the spooler services as noted on many blogs: > Problem installing Lexmark x4650 - error 0x000006be, Print Spooler, Add Printer > > 1. I attempted to manually clean all my drivers and registry changes > as noted here: > http://members.shaw.ca/bsanders/CleanPrinterDrivers.htm > This did not help > > 2. I traversed HP's site and found this tidbit: > http://h10025.www1.hp.com/ewfrf/wc/d...reg_R1002_USEN > > No luck yet. > > 3. I traversed MS support and found this KB: > http://support.microsoft.com/kb/324757 > I did go to C:/windows/system32/spool/ > > I deleted all drivers - residue from the XP builds. > > The PRINTERS directory was empty (obviously no prointers were every > installed) > > I deleted all printprocs. > > > Many blogs indicated this successfully worked for different users. > > However, this did not resolve the problem. > > > 4. I reinstalled Vista > No luck there either > > > 5. I tried installing a Vista CD installation of the Laserjet 4700 > thinking a full Cd isntall might work : > > No luck > > 6. I tried downloading the PrintFlush-1.3 utility to clean the Spooler > settings and queues. > No luck > > 7. I downloaded the Print Spooler Fix wizard. While this didn't work > it did clue me into some registry settings that were dangling. I > deleted them. > Still no luck > > 8. Finally I went to C:/windows/system32 and added columns to the > directory listing to indicate company names. I deleted all HP drivers > I could find. I have to say the HP AIO 8150 left a shotgun of driver > residue. > > > ----------------------------------------- The fix > -------------------------------- > Now begins some deeper debugging and resolution. > > As you see I have stripped my registry settings, drivers, monitors, > and whatnot. You can assume I have no print drivers at this point. > > 1. I went to Device Manager and reviewed the logs. Under Event Views - Quote: > > Windows Logs -> Application. I noticed failures related to the > > "The print spooler cannot start because the PrinterBusEnumerator could > not start. Error code 0x80070006. This can occur because of system > instability or a lack of system resources." > > 2. I searched Google and found a relationship between > PrinterBusEnumerator and the UMBus (User Mode Bus). > > 3. I went to Device Manager again and clicked on View -> Show Hidden > Devices. Selected System Devices. And Uninstalled both the UMBus > Enumerator as well as teh UMBus Root Bus Enumerator. > > 4. Rebooted. > > 5. Went to Control Panel. Selected Add Hardware. > > 6. Selected Install the Hardware Manually. > > 7. Clicked on the first selection: "Show All Devices" > > 8. Added back bot the Microsoft UMBus Enumerator and the UMBus Root > Bus Enumerator. > > 9. Rebooted. > > 10. Went to add printer. And could then add back my Color Laserjet > 4600. > > 11. Printed a test page and application document as a test. > > > Hope that might help someone in the future. > > |
| | Re: How I fixed my Vista Print Spooler Problems Something else that may help is the Print Spool Repair Utility from http://www.print-spool.com It's designed to take care of your spool jam problem fast and with just a few easy clicks of your mouse! There's nothing to install and nothing to edit! Anyone can use this powerful utility without any real knowledge of printers or computers, however computer technicians love our Printer Problem Solver on-site wherever they go because it can run directly from a usb drive! It's that portable! No complicated or messy installations required! It's small, powerful, easy to use and it works in SECONDS! Don't pay $34.99 or more for out-of-warranty overseas technical support EVERY TIME it happens! It even works with Lexmark printers! Try out the demo today! -- Edgeofourpants ------------------------------------------------------------------------ Edgeofourpants's Profile: http://forums.techarena.in/members/edgeofourpants.htm View this thread: http://forums.techarena.in/vista-print-fax/1057938.htm http://forums.techarena.in |
| | RE: How I fixed my Vista Print Spooler Problems Thank you for your excellent post. I have been fighting with this printer installation problem for two days. I am a very experienced PC user but this new Vista thing is making me crazy. Your fix worked and has certainly saved me more frustration! Thanks Again! "perrylea@xxxxxx" wrote: Quote: > I have been a long time user of Windows XP SP2. I had recently > putchased Vista Ultimate with the intent to upgrade my XP system. > > The principal problem was all attempts to add a printer resulted in > errors stemming from the Print Spooler Service. > > Before I begin let me preface my environment: > > Intel 2.8 GHz machine with 2 GB RAM and ATI 1300 video. XP SP2 as I > mentioned. > I have used over the years the following imaging devices: > > a. HP Color LaserJet 4650 > b. HP 8150 AIO Injet/Scanner/Fax > c. HP 9100 Digital sender > > I should note that the digital sender has long since been removed. > The 8150 is seldom used. Both of these devices had left a long > residue of drivers and services on my XP box. The Laserjet only used > a PCL6 driver. > > > ------ The Vista Experience --------- > Now begins my 14 hours of debug joy. The Vista install went fairly > smoothly. The Windows Compatibility check noted some issues with > Symmantec AntiVirus, ATI veido, Sigmatel Audio, Windows MGR 5.1, and > the Common Client. Nothing seemed out of hte ordinary so I went > with an upgrade install of Vista Ultimate. > > The installation took about 3 hours. > > When complete I verified that video, networking, my critical > applications, and device worked. Most did, except for the DVD drive. > There is a BLOG dedicated to that issue. > > The main problem was trying to add a printer. > > > > All attempts to add a printer resulted in a pop up showing: > "windows can't open add printer. the local print spooler is not > running" > > If I manually restarted the Print Spooler service and quickly add a > printer in the Control Panel dialogue I got a different error: > "0x000006be error" > > > So began the Google searches for help. > > 1. I attempted to restart the spooler services as noted on many blogs: > Problem installing Lexmark x4650 - error 0x000006be, Print Spooler, Add Printer > > 1. I attempted to manually clean all my drivers and registry changes > as noted here: > http://members.shaw.ca/bsanders/CleanPrinterDrivers.htm > This did not help > > 2. I traversed HP's site and found this tidbit: > http://h10025.www1.hp.com/ewfrf/wc/d...reg_R1002_USEN > > No luck yet. > > 3. I traversed MS support and found this KB: > http://support.microsoft.com/kb/324757 > I did go to C:/windows/system32/spool/ > > I deleted all drivers - residue from the XP builds. > > The PRINTERS directory was empty (obviously no prointers were every > installed) > > I deleted all printprocs. > > > Many blogs indicated this successfully worked for different users. > > However, this did not resolve the problem. > > > 4. I reinstalled Vista > No luck there either > > > 5. I tried installing a Vista CD installation of the Laserjet 4700 > thinking a full Cd isntall might work : > > No luck > > 6. I tried downloading the PrintFlush-1.3 utility to clean the Spooler > settings and queues. > No luck > > 7. I downloaded the Print Spooler Fix wizard. While this didn't work > it did clue me into some registry settings that were dangling. I > deleted them. > Still no luck > > 8. Finally I went to C:/windows/system32 and added columns to the > directory listing to indicate company names. I deleted all HP drivers > I could find. I have to say the HP AIO 8150 left a shotgun of driver > residue. > > > ----------------------------------------- The fix > -------------------------------- > Now begins some deeper debugging and resolution. > > As you see I have stripped my registry settings, drivers, monitors, > and whatnot. You can assume I have no print drivers at this point. > > 1. I went to Device Manager and reviewed the logs. Under Event Views - Quote: > > Windows Logs -> Application. I noticed failures related to the > > "The print spooler cannot start because the PrinterBusEnumerator could > not start. Error code 0x80070006. This can occur because of system > instability or a lack of system resources." > > 2. I searched Google and found a relationship between > PrinterBusEnumerator and the UMBus (User Mode Bus). > > 3. I went to Device Manager again and clicked on View -> Show Hidden > Devices. Selected System Devices. And Uninstalled both the UMBus > Enumerator as well as teh UMBus Root Bus Enumerator. > > 4. Rebooted. > > 5. Went to Control Panel. Selected Add Hardware. > > 6. Selected Install the Hardware Manually. > > 7. Clicked on the first selection: "Show All Devices" > > 8. Added back bot the Microsoft UMBus Enumerator and the UMBus Root > Bus Enumerator. > > 9. Rebooted. > > 10. Went to add printer. And could then add back my Color Laserjet > 4600. > > 11. Printed a test page and application document as a test. > > > Hope that might help someone in the future. > > |
| Print spooler problems in Vista Home Premium 64bit | Vista print fax & scan | |||
| HOw do I start the print spooler so I can install my print drivers? | Vista installation & setup | |||
| Vista Print Spooler problems | Vista General | |||
| Print Spooler problems, tried all the fixes listed and no dice... | Vista print fax & scan | |||
| Vista Print Spooler | Vista print fax & scan | |||
