| Guest | Lexmark Z 707 problem I have installed the software for my lexmark Z707 photo printer this was done in compatibility mode for Win XP sp2 The installation went very well with no errors and the software works just fine However I have no communications through the usb port why is this ?? FYI the printer is connected directly to the PC not through a hub Does anybody else have this problem |
| Guest | RE: Lexmark Z 707 problem This is now the third post i've heard with this problem. I too have the same problem..seems to be with Lexmark printers right now. I have a z605...although i do see lexmark drivers that vista does support, however nothing for us....hmmm..hopefully someone has an answer "Will Schuitman" wrote: > I have installed the software for my lexmark Z707 photo printer > this was done in compatibility mode for Win XP sp2 The installation went > very well with no errors and the software works just fine > However I have no communications through the usb port why is this ?? > FYI the printer is connected directly to the PC not through a hub > > Does anybody else have this problem > > |
| Lexmark X5650 Printer Problem | Vista print fax & scan | |||
| Problem with Lexmark x2480 scanner | Vista print fax & scan | |||
| Lexmark driver problem | Drivers | |||
| Lexmark Drivers for Lexmark 2300 series printers | Vista General | |||
| lexmark printer problem | Vista General | |||
