Help! I accidently deleted the print spooler.
  1. #1
    Newbie
    Vista Home Premium 32bit
    Local Time: 10:56 PM
    Does anyone know where to find a new install for the print spooler or is there such a thing? (I feel like an idiot)
  2. #2
    barman58's Avatar
    Post No Evil ;)
    Newport, South Wales, UK
    Windows 7 RC x64 Vista HP x86
    Local Time: 05:56 AM
    uk uk wales
    Re: Help! I accidently deleted the print spooler.
    Hi, argento2665 and welcome to the Vista Forums,
    First thing, when did this happen?
    If it is a recent problem would suggest you try a system restore
    System Restore - How to - Vista Forums
    If this does not help you can try a system File Check ...
    System Files - SFC Command - Vista Forums
    If all else fails ther is the repair install ...
    Repair Install For Vista
    With all these I am assuming you have a Vista install DVD if not you can have a look at this which will enable some of the above options ...
    Create a Recovery Disc - Vista Forums
    If this fails a reinstall may be the only option (either from original DVD or via the restore option for laptops
  3. #3
    Bob Headrick [MVP] Guest
    argento2665" <guest@xxxxxx-email.com> wrote in message
    news:45de04b519d202f8902eb2f6a143ef4c@xxxxxx-gateway.com:
    Is the spooler really deleted or is it just stopped? If the latter open
    an elevated command window (start, type cmd.exe in the start search box,
    hold control and shift and press enter). In the command window type:
    Net start spooler
    Regards,
    Bob Headrick
  4. #4
    Newbie
    vista 64
    Local Time: 12:56 AM
    usa
    ________
    Sunday 4/11/09 10:19am
    Thanks for the SMC.Exe idea, I used it.
    The SMC.Exe step worked, as the computer then showed:
    "The Print Spooler service is starting.
    the Print Spooler service ws started successfully."
    I typed: Exit.
    Then I tried to print, and tried to add a printer, and rec'd a windows message:
    "Spooler Subsystem App stopped working and was closed."
    Any ideas? Thanks much. Bob Holland
    Email to me, if you don't mind: NiceGuy_20850 @yahoo.com
    ________
  5. #5
    brummyfan's Avatar
    Brummy
    Birmingham
    Vista Home Premium SP2 32bit.
    uk uk england
    I think you have to start the Print Spooler service in "services".
    Type "services" in start search.HTH.
  6. #6
    Newbie
    vista 64
    usa
    Hi 4/12/09 12:40pm
    Thanks brummyfan. I appreciate the ideas, and for your responding.
    The 'Services' step and then clicking on print spooler and then changing it to Automatic, does work but only until I try to print something, and then again I get a windows message that the Spooler Subsystem App has stopped.
    Since I am not real good at computer geek stuff, I eventually resorted to a Restore from a week ago, and so far, I have printed 2 tax returns and 1 set of other forms in TaxCut, so it seems to be working. Again, thanks for responding, and sharing.
    Bob
    _______
Help! I accidently deleted the print spooler. problems?
accidently deleted email sue anderson Vista mail 5 13 Jul 2009
Accidently deleted pictures danielle Vista music pictures video 1 08 Jul 2008
Accidently deleted recycle bin RellikZephyr General Discussion 4 28 Feb 2008
accidently deleted program JJ Vista hardware & devices 1 06 May 2007
accidently deleted recycle bin stevhawk89 Vista file management 2 12 Jun 2006
