| | Printing problems Hi I have two problems: 1) I cannot print from Office apps unless I disable User Account Control. MS are looking in to this but does anybody out there have any ideas? 2) If I try to print more than one copy of a document I get the square of the number of copies which I selected. For example if I ask for 2 I get 4, 3 I get 9 etc. I asked Lexmark about these two issues and they say they are MS problems. I would be grateful for help... John |
| | Re: Printing problems If this was a MS problem, it would occur with almost all printer drivers. It does not. (One of the standard Lexmark answers is basically it's somebody else's problem.) "John Bobin" <johnwdbobin@xxxxxx> wrote in message news:C249B382-BE5A-4638-A6A0-0CE396B90308@xxxxxx Quote: > Hi > I have two problems: > 1) I cannot print from Office apps unless I disable User Account Control. > MS > are looking in to this but does anybody out there have any ideas? > 2) If I try to print more than one copy of a document I get the square of > the number of copies which I selected. For example if I ask for 2 I get 4, > 3 > I get 9 etc. > I asked Lexmark about these two issues and they say they are MS problems. > I > would be grateful for help... > John |
| Re: ie 7 printing problems | Vista print fax & scan | |||
| Re: still problems with printing in ie7 | Vista print fax & scan | |||
| Printing Problems | Vista General | |||
| Downgrading from 64bit Vista to 32bit, Media Center problems, web page printing problems | Vista installation & setup | |||
