Go Back   Vista Forums > Vista Newsgroups > Vista print fax & scan
Vista - Printing problem
Old 11-25-2008   #1 (permalink)
MrKite
Printing problem
This has probably been covered before but here goes. I cannot print from my
Vista laptop (wireless connection to network, Vista desktop connected to
router via ethernet, printer connected to desktop). Network is good,
everything sees everything, no problems.
I have been dealing with this for months. Finally, I found a thread where
it said to Add a Printer using local network instead of wireless. This
seemed to work, even printed the test page. After printing the test page
properly, however, printing fails again. I tried to print my Belarc report,
and I get "Printer is not responding". I get the printer icon in the task
bar saying "This document has been sent to the printer". Printer just sits
there, nothing. I have tried every configuration I can think of when
installing the printer on the laptop, but the results are the same. Any
ideas?
Printing Problem Live Mail
Re-printing problem Drivers
printing problem Vista General
printing problem Vista print fax & scan
Printing Problem Vista print fax & scan
