| | Vista Business - Print Spooler will not stay up I upgraded from XP to Vista last week. Since then I can not print any large documents. It will print a few pages and then stop. When I go to printers I have no printers. I normally have two local and 6 network printers showing. When I check the print spooler it is not running. I changed the restart parameters to always restart, but there are times when it takes a while before restarting. If I click in the printers window the print spooler cancels and restarts. If I display the properties on a printer the spooler restarts. Any ideas? |
| | Re: Vista Business - Print Spooler will not stay up If you had a Dell printer installed you needed to run the Dell upgrade software before upgrading to Vista. Most likely some print software is corrupting the memory used by the print spooler and forcing the process to terminate. Follow Bruce's recommendations http://members.shaw.ca/bsanders/CleanPrinterDrivers.htm -- Alan Morris Windows Printing Team Search the Microsoft Knowledge Base here: http://support.microsoft.com/search/?adv=1 This posting is provided "AS IS" with no warranties, and confers no rights. <mike.wood@xxxxxx> wrote in message news:49467f27.1552734@xxxxxx Quote: >I upgraded from XP to Vista last week. Since then I can not print any > large documents. It will print a few pages and then stop. When I go > to printers I have no printers. I normally have two local and 6 > network printers showing. > > When I check the print spooler it is not running. I changed the > restart parameters to always restart, but there are times when it > takes a while before restarting. > > If I click in the printers window the print spooler cancels and > restarts. If I display the properties on a printer the spooler > restarts. > > Any ideas? |
| Vista print spooler problem | Vista print fax & scan | |||
| print spooler problem with Vista | Vista General | |||
| HOw do I start the print spooler so I can install my print drivers? | Vista installation & setup | |||
| Vista Print Spooler | Vista print fax & scan | |||
| Print Spooler - Vista | Vista print fax & scan | |||
