Go Back   Vista Forums > Vista Newsgroups > Vista print fax & scan
Vista - Re: Using fax in small home network
Old 01-08-2009   #1 (permalink)
Pedro at DLA
Thanks Russ.
Do you know of a simple inexpensive program that will do it? (Simple as in
easy to use?)
"Russ Valentine [MVP-Outlook]" wrote:
Quote:
> It is not possible to share any of the Microsoft Fax end user client
> software. Never has been. Never will be.
> Russ Valentine
> [MVP-Outlook]
> "Pedro at DLA" <PedroatDLA@xxxxxx> wrote in message
> news:BFCA35B7-80EF-4372-81C2-ADEAF85385B1@xxxxxx
Quote:
> > Hullo. We have four or so computers on a home office network, with one of
> > them being used as a fax receiver, using the fax software that comes with
> > Windows. We want to be able to send faxes from each computer, via that one
> > that is connected to the phone line. It has XP, most of the others have
> > Vista.
> > Can anyone help?
> > Cheers,
> > Pedro, Canberra, Australia
Old 01-08-2009   #2 (permalink)
No, because I haven't the time to stray beyond Microsoft's offers. Hopefully
others here might.
Russ Valentine
[MVP-Outlook]
news:3618A879-ED6D-409B-A185-3CD593917CE7@xxxxxx
Quote:
> Thanks Russ.
> easy to use?)
>> Russ Valentine
>> [MVP-Outlook]
>> > of
>> > with
>> > one
>> > Vista.
>> > Can anyone help?
>> > Cheers,
trying to setup a small home network. Network & Sharing
Re: Using fax in small home network Vista print fax & scan
Setting up a small home network Network & Sharing
