| | Re: Using fax in small home network "Pedro at DLA" <PedroatDLA@xxxxxx> wrote in message news:BFCA35B7-80EF-4372-81C2-ADEAF85385B1@xxxxxx Quote: > Hullo. We have four or so computers on a home office network, with one of > them being used as a fax receiver, using the fax software that comes with > Windows. We want to be able to send faxes from each computer, via that one > that is connected to the phone line. It has XP, most of the others have > Vista. > > Can anyone help? > > Cheers, > > Pedro, Canberra, Australia As far as I am aware, each computer would have to have an analogue modem installed, and then each machine would go into conflict with the others regarding receiving a fax.. Look into buying a cheap fax machine.. -- Mike Hall - MVP How to construct a good post.. http://dts-l.com/goodpost.htm How to use the Microsoft Product Support Newsgroups.. http://support.microsoft.com/default...help&style=toc Mike's Window - My Blog.. http://msmvps.com/blogs/mikehall/default.aspx |
| | Re: Using fax in small home network "Mike Hall - MVP" <mikehall@xxxxxx_mvps.com> wrote in message news:uycEtmmcJHA.4124@xxxxxx Quote: > "Pedro at DLA" <PedroatDLA@xxxxxx> wrote in message > news:BFCA35B7-80EF-4372-81C2-ADEAF85385B1@xxxxxx Quote: >> Hullo. We have four or so computers on a home office network, with one of >> them being used as a fax receiver, using the fax software that comes with >> Windows. We want to be able to send faxes from each computer, via that >> one >> that is connected to the phone line. It has XP, most of the others have >> Vista. >> >> Can anyone help? >> >> Cheers, >> >> Pedro, Canberra, Australia > > As far as I am aware, each computer would have to have an analogue modem > installed, and then each machine would go into conflict with the others > regarding receiving a fax.. > > Look into buying a cheap fax machine.. > > > -- > Mike Hall - MVP > How to construct a good post.. > http://dts-l.com/goodpost.htm > How to use the Microsoft Product Support Newsgroups.. > http://support.microsoft.com/default...help&style=toc > Mike's Window - My Blog.. > http://msmvps.com/blogs/mikehall/default.aspx > > > > of any of the Microsoft Fax programs so there would be no conflict if each machine is set to transmit fax but only one set to receive. |
| trying to setup a small home network. | Network & Sharing | |||
| Re: Using fax in small home network | Vista print fax & scan | |||
| Setting up a small home network | Network & Sharing | |||
