Go Back   Vista Forums > Vista Newsgroups > Vista print fax & scan
Vista - Printer communication problem in x64 resolved
Old 01-27-2009   #1 (permalink)
adg
Ultimate x64, Ultimate x32, XP, Linux
Hi:
Just a quick post to report that after three days of trying to get my Canon i9100 to communicate with any program whatsoever, I discovered the USB Filter loaded when I set up my ATI drivers was the culprit -- uninstalling the USB filter has left me a happy camper, with a fully functional printer.
Just wish someone else had discovered this ahead of me (or reported it) so a quick search (lazy me) would have brought the solution to me
bst
adg
Old 01-27-2009   #2 (permalink)
slimorse
RE: Printer communication problem in x64 resolved
If you would, please let me the step by instructions for this resolution. It
may apply to my "printer won't stay installed" post.
thx
"adg" wrote:
Quote:
> Hi:
> functional printer.
> me
> bst
> adg
> adg
Old 01-28-2009   #3 (permalink)
adg
Re: Printer communication problem in x64 resolved
Hi:
I opened Control Panel > Uninstall Programs > Chose the ATI Catalyst entry
Then, when it opened, I chose Uninstall, Custom and then chose USB Filter.
Once that was uninstalled, my printer again worked.
Did this in both an old installation of x64 and a clean install on a new drive and it worked both times.
Hope this helps
adg
Printer communication system has stopped working? Vista print fax & scan
Printer communication system stopped working Vista print fax & scan
Printer Communication Vista General
Printer Communication Not Available error Vista print fax & scan
Printer communication has failed Vista print fax & scan
