| Newbie | Fax feature on HP Solutions Center does not work for Officejet J6480 Help, I just bought an Officejet J6480 and have endlessly uninstall and installed the software with HP's help to no avail. The "Send a fax" feature on the Solutions Center just does not work, it keeps telling me " The scan fax failed, retry the fax". I can fax, scan, copy directly from the printer. I can also scan, convert from the Solutions center but the "send a fax" feature is the only one that doesn't work. Can anyone help me please. Everything else works fine. |
| HP Officejet J6480 Sends but won't Receive Faxes IF the COmputer is ON!! | Vista print fax & scan | |||
| HP Officejet J6480 | Vista General | |||
| Problem Reports and Solutions Feature | Vista General | |||
| HP OfficeJet 7310 Vista full-feature software & drivers available | Vista hardware & devices | |||
| HP OfficeJet 7310 Vista full-feature software & drivers available | Vista print fax & scan | |||
