| | Spooler SubSystem problems reinstalling Lexmark Please help! I have spent so much time on this problem already. I had installed Lexmark all-in-one X5260 and an old Epson printer on my Vista Business Sony Vaio since early 2008 without problem. When I removed the old Epson printer yesterday from my computer, I did not do it completely and there was still a test page in the Epson spooler. I replugged in the Epson printer and deleted them. Since then printing with Lexmark, uninstalling, re-installing have all not worked or been aborted. Sometimes without any response. When trying to print a doc the spooler symbol appears in the lower right but is not openable and says there are 0 docs. When trying to print a test page it goes immediately to an error message saying the test page did not print and was deleted from the print queue. Sometimes the installation process generates a Spooler SubSystem App Closed error message. The full error details are given below at the bottom of this post. I did a system restore to the day before I removed the Epson printer and made sure there was nothing in the spooler before removing it. However I still cannot get the Lexmark to function. I uninstalled Lexmark and followed the advice from the other posts especially Spooler SubSystem App with Alan Morris and Eddie. I followed the instructions recommended in http://members.shaw.ca/bsanders/CleanPrinterDrivers.htm However I was unable to do the "net stop spooler" and "net start spooler" commands in the procedure, I got a response, "System error 5 has occurred. Access is denied." At the command prompt I was not at the root directory, I was at c:\Users\vaio. Also I am the only user of my laptop and have the printer in a USB port, not networked. I presumed I had no printer drivers or spoolers left. I then installed the Lexmark using the Series 5200 CD. First it stopped at the 2nd phase of "transferring software". I rebooted and started the installation again. This time it stopped responding at the "transferring software" stage. Rebooted and tried installation. This time, after a long time, it finally progressed to the third phase of "installing software", but before the final phase of "detecting your printer" I got the Spooler SubSystem App closed error message. The Lexmark now shows up in my printers and appears to sense the ink levels and that it is plugged in USB port 1. But no printing. This Lexmark series doesn't support Vista and they don't even show X5260 on their website, just X5250 and X5270, although they don't provide Vista software for these either. Any help would be deeply appreciated. Reading through other posts like Perrylea's "How I fixed my Vista Print Spooler problems" makes me despair that it's really complicated. -Mrs Manolo (Details of Spooler SubSystem App error message) Problem signature: Problem Event Name: APPCRASH Application Name: spoolsv.exe Application Version: 6.0.6001.18000 Application Timestamp: 4791956c Fault Module Name: StackHash_9e31 Fault Module Version: 6.0.6001.18000 Fault Module Timestamp: 4791a7a6 Exception Code: c0000374 Exception Offset: 000b015d OS Version: 6.0.6001.2.1.0.256.6 Locale ID: 2057 Additional Information 1: 9e31 Additional Information 2: 5ede27626b0593803c99be8e078b9a94 Additional Information 3: b469 Additional Information 4: c1c3e840e6e8160ff6ded858147157fa (End of error message) |
| | Re: Spooler SubSystem problems reinstalling Lexmark MrsManolo wrote: Quote: > Please help! I have spent so much time on this problem already. I had > installed Lexmark all-in-one X5260 and an old Epson printer on my Vista > Business Sony Vaio since early 2008 without problem. When I removed the old > Epson printer yesterday from my computer, I did not do it completely and > there was still a test page in the Epson spooler. I replugged in the Epson > printer and deleted them. Since then printing with Lexmark, uninstalling, > re-installing have all not worked or been aborted. Sometimes without any > response. When trying to print a doc the spooler symbol appears in the lower > right but is not openable and says there are 0 docs. When trying to print a > test page it goes immediately to an error message saying the test page did > not print and was deleted from the print queue. Sometimes the installation > process generates a Spooler SubSystem App Closed error message. The full > error details are given below at the bottom of this post. > I did a system restore to the day before I removed the Epson printer and > made sure there was nothing in the spooler before removing it. However I > still cannot get the Lexmark to function. > I uninstalled Lexmark and followed the advice from the other posts > especially Spooler SubSystem App with Alan Morris and Eddie. I followed the > instructions recommended in > http://members.shaw.ca/bsanders/CleanPrinterDrivers.htm > However I was unable to do the "net stop spooler" and "net start spooler" > commands in the procedure, I got a response, "System error 5 has occurred. > Access is denied." At the command prompt I was not at the root directory, I > was at c:\Users\vaio. Also I am the only user of my laptop and have the > printer in a USB port, not networked. > I presumed I had no printer drivers or spoolers left. > I then installed the Lexmark using the Series 5200 CD. First it stopped at > the 2nd phase of "transferring software". I rebooted and started the > installation again. This time it stopped responding at the "transferring > software" stage. Rebooted and tried installation. This time, after a long > time, it finally progressed to the third phase of "installing software", but > before the final phase of "detecting your printer" I got the Spooler > SubSystem App closed error message. The Lexmark now shows up in my printers > and appears to sense the ink levels and that it is plugged in USB port 1. But > no printing. > This Lexmark series doesn't support Vista and they don't even show X5260 on > their website, just X5250 and X5270, although they don't provide Vista > software for these either. > Any help would be deeply appreciated. Reading through other posts like > Perrylea's "How I fixed my Vista Print Spooler problems" makes me despair > that it's really complicated. > -Mrs Manolo > > > (Details of Spooler SubSystem App error message) > Problem signature: > Problem Event Name: > APPCRASH > Application Name: > spoolsv.exe > Application Version: > 6.0.6001.18000 > Application Timestamp: > 4791956c > Fault Module Name: > StackHash_9e31 > Fault Module Version: > 6.0.6001.18000 > Fault Module Timestamp: > 4791a7a6 > Exception Code: > c0000374 > Exception Offset: > 000b015d > OS Version: > 6.0.6001.2.1.0.256.6 > Locale ID: > 2057 > Additional Information 1: > 9e31 > Additional Information 2: > 5ede27626b0593803c99be8e078b9a94 > Additional Information 3: > b469 > Additional Information 4: > c1c3e840e6e8160ff6ded858147157fa > (End of error message) Drivers normally come from where you got the printer, so if you bought it from Dell, check there. If the drives should come from Lexmark and they don't show any Vista drivers, you may need to use the Vista drivers if there are any. I found one thread that says Lexmark advised using the X5250 drivers. I did not check for any other countries beside the US. http://www.downloaddelivery.com/en/cpddrivers/440.html If those drivers work, great, otherwise. I would probably try uninstalling the printer-if it won't uninstall, try it in safe mode. Reboot and plug in the USB cable. Does Vista say it is installing a driver? If that doesn't work, go to the install printers dialogue and follow it through and see if Vista has a driver for the printer. Clark |
| Spooler Subsystem App problems with network printer | Vista print fax & scan | |||
| Spooler Subsytem App problems reinstalling Lexmark | Vista print fax & scan | |||
| Spooler Subsystem problems reinstalling Lexmark | Vista print fax & scan | |||
| spooler subsystem app | Vista performance & maintenance | |||
| Spooler SubSystem App | Vista print fax & scan | |||
