Go Back   Vista Forums > Vista Newsgroups > Vista print fax & scan
Vista - Network Printer problem
Old 02-13-2009   #1 (permalink)
Simon Thomson
I am the last member of my family to get my own new laptop, the other 3
laptops and my son's girlfriend's laptop sees the shared printer on the main
PC connected by a CAT5e cable to the Netgear Wireless hub. I however, can
not see anything! I have tried renaming the network on my laptop (which sees
the internet but not the printer), I was wondering if it was the Firewall on
the main Computer (Microsoft) and the one on my laptop (Symantec), so I
disabled the Symantec firewall and it made no difference!
If anyone has any suggestions or ideas...
Simon Thomson
Old 02-13-2009   #2 (permalink)
Ten Pin Bowling
Re: Network Printer problem
"Simon Thomson" <simon.thomson@xxxxxx> wrote in message
news:%23CS3AThjJHA.4912@xxxxxx
>main PC connected by a CAT5e cable to the Netgear Wireless hub. I however,
>can not see anything! I have tried renaming the network on my laptop (which
>sees the internet but not the printer), I was wondering if it was the
>Firewall on the main Computer (Microsoft) and the one on my laptop
>(Symantec), so I disabled the Symantec firewall and it made no difference!
> Simon Thomson
OK have you used the Add Printer Wizard on your comp....with Symantec
TOTALLY disabled.
Old 02-13-2009   #3 (permalink)
Simon Thomson
Thank you so much... I tried this about a week ago to no avail I can now
print off my time sheets!!! Thank you, thank you, thank you!!!
Simon Thomson
"Ten Pin Bowling" <Pin1@xxxxxx> wrote in message
news:dpmdnYB_0oM6SQjUnZ2dnUVZ8tninZ2d@xxxxxx
>>(which sees the internet but not the printer), I was wondering if it was
>>the Firewall on the main Computer (Microsoft) and the one on my laptop
>> Simon Thomson
> TOTALLY disabled.
Old 02-13-2009   #4 (permalink)
Ten Pin Bowling
news:3026B593-B95A-4378-8FA2-9E1C7D157DAD@xxxxxx
> Simon Thomson
>>>however, can not see anything! I have tried renaming the network on my
>>>laptop (which sees the internet but not the printer), I was wondering if
>>>it was the Firewall on the main Computer (Microsoft) and the one on my
>>>laptop (Symantec), so I disabled the Symantec firewall and it made no
>>>difference!
>>> Simon Thomson
>> TOTALLY disabled.
now you have to go through Symantecs settings, on each comp, to input your
comps IP address in the allow settings.............sorry I dumped Symantec
in favour of Kaspersky so cannot recall the exact method.
network printer problem Network & Sharing
problem with my network printer Network & Sharing
Network printer problem Vista print fax & scan
Problem with Network printer over wireless network. Vista print fax & scan
Network Printer and Wireless Network problem Vista installation & setup
