| Vista Home Premium 64bit | Print spooler problems in Vista Home Premium 64bit I was printing fine until one day I got an error that said, Print Spooler not running. I restarted the print spooler and tried again. I got the same message. I have reinstalled drivers and rebooted the system. I still get the same message. I can not add a printer or see the printers that are installed. |
| | Re: Print spooler problems in Vista Home Premium 64bit Open an elevated command prompt and type net start spooler does it say the spooler started or do you get an error? -- Alan Morris Windows Printing Team Search the Microsoft Knowledge Base here: http://support.microsoft.com/search/?adv=1 This posting is provided "AS IS" with no warranties, and confers no rights. "LBraley" <guest@xxxxxx-email.com> wrote in message news:b342af72ec09d8f79515a352b5a42fed@xxxxxx-gateway.com... Quote: > > I was printing fine until one day I got an error that said, Print > Spooler not running. I restarted the print spooler and tried again. I > got the same message. I have reinstalled drivers and rebooted the > system. I still get the same message. I can not add a printer or see > the printers that are installed. > > > -- > LBraley |
| Vista Ultimate x64 | Re: Print spooler problems in Vista Home Premium 64bit Because I have the same extremly strange and illogical problem: "CMD run as Administrator" as you suggest lets me start the spooler but with the next print job the "spooler does not work no solution ready" comes back. And now hold your breath: I moved to a bigger system drive recently, did the cloning with "Acronis True Image 10 full version". After the cloning everything worked fine until yesterday afternoon when suddenly the spooler pains began out of nowhere. So I swithed back to the old (slow) harddrive where everything works fine still and I can print. I created a sector-by-sector-image of that drive and reloaded it onto the fast drive. Does not print. Also the infamous 2007 Microsoft knowledge base article ("delete Acrobat Professional 8.1.x and all printers by hand in safe mode...") does not help a bit. No piece of non-working software can technically be in a sector by sector image of a drive that works just fine. The reason must lie somewhere outside the box. I have to switch back to the old drive until a solution is provided by whoever is responsible for the error. Frank |
| Vista Ultimate x64 | Re: Print spooler problems in Vista Home Premium 64bit S O L U T I O N !!!!!! OK. Its a toxic PDF. If you want to reproduce the error, just try to open the following PDF in Vista64SP1/Acrobat 8.1.x: http://afrika.net/temp/toxic_pdf I renamed it because I do not want to accidentially kill my spooler, but if you are an Adobe or Microsoft technician, try to find the function call this PDF sends to Vista x64 through Adobe Acrobat 8.1.3 in a sandbox / virtual environment. This is how the spooler is killed. Get rid of that and provide updates, folks. Not all of the people out there have a long work experience in testing computer hardware and sofware as a computer journalist. Frank Mehr verkaufen mit professionellen Produktfotos und wirksamer Werbung von Frank Fremerey PR & Firmenkommunikation, Fotokunst & Text! Last edited by FRF; 03-17-2009 at 09:12 AM.. |
| | RE: Print spooler problems in Vista Home Premium 64bit I have the exact same problem. Any insight? "LBraley" wrote: Quote: > > I was printing fine until one day I got an error that said, Print > Spooler not running. I restarted the print spooler and tried again. I > got the same message. I have reinstalled drivers and rebooted the > system. I still get the same message. I can not add a printer or see > the printers that are installed. > > > -- > LBraley > |
| | #6 (permalink) |
| | Re: Print spooler problems in Vista Home Premium 64bit Start by getting the spooler service running. You will need to delete the print drivers that are causing the spooler to crash from the registry. If you have a Lexmark there are a couple other steps. http://members.shaw.ca/bsanders/CleanPrinterDrivers.htm -- Alan Morris Windows Printing Team Search the Microsoft Knowledge Base here: http://support.microsoft.com/search/?adv=1 This posting is provided "AS IS" with no warranties, and confers no rights. "n601ap" <n601ap@xxxxxx> wrote in message news:8542D40B-9EA7-4F7A-9DCE-C1E1D3CC7B28@xxxxxx Quote: >I have the exact same problem. Any insight? > > "LBraley" wrote: > Quote: >> >> I was printing fine until one day I got an error that said, Print >> Spooler not running. I restarted the print spooler and tried again. I >> got the same message. I have reinstalled drivers and rebooted the >> system. I still get the same message. I can not add a printer or see >> the printers that are installed. >> >> >> -- >> LBraley >> |
| How I fixed my Vista Print Spooler Problems | Vista print fax & scan | |||
| Problems with Vista Home Premium 64bit | Vista performance & maintenance | |||
| Upgrade from Home Premium 64bit to Ultimate 64bit - No 64bit Media | Vista installation & setup | |||
| Installing Vista Home Premium 64bit OEM problems | Vista installation & setup | |||
| Vista Print Spooler problems | Vista General | |||
