Go Back   Vista Forums > Vista Newsgroups > Vista print fax & scan
Vista - Print job in queue gets port from next print job
Old 02-26-2009   #1 (permalink)
Michael Harvey
Hi, this happens with printer connected to non-existent LPT1 port or TCP/IP
port.
1) Send first print job, when calling StartDoc set DOCINFO lpszOutput to
NULL, it sits in front of queue, no problem.
2) Send second print job, same as first job, it sits behind first job in
queue, no problem.
3) Send third print job, but this time when calling StartDoc set DOCINFO
lpszOutput to a file path. The file is new and it is on either ProgramData or
a network drive which gives permission to create. The second print job
magically gets the 3rd print jobs file in it's port, as shown when viewing
the print queue. Futhermore, third print job hangs waiting for EndDoc.
Print jobs stuck on Print queue Network & Sharing
Print Queue Logging VB Script
After printing several documents, the print queue hangs, print st Vista print fax & scan
Re: Print hangs in queue Vista print fax & scan
Print Queue Problem Vista print fax & scan
