Go Back   Vista Forums > Vista Newsgroups > Vista print fax & scan
Vista - Printer Will Not Print
Old 03-06-2009   #1 (permalink)
Vista Home Premium
So i got a Dot Matrix Panasonic KX P2123 for my computer. My use of this is for tatoo stencils in which you dont need the ribbon and such. But I just got it todayand went to hook it up to my computer and hooked it up with a parallel/USB cord. Once I did so, I went to add printer, and added it just fine, automatically had the driver installed. Which I was trilled about!
Then I went to print a test page as prompted with adding a printer and got nothing.
Then I tried from photoshop. Nothing. And from irfan view. Nothing. In the buffer it says error. I cant seem to figure out what I am doing wrong I will include pictures to see if anyone may know of have suggestions! Thanks!
Old 03-06-2009   #2 (permalink)
Alan Morris [MSFT]
Re: Printer Will Not Print
I suggest a parallel port rather than the USB/parallel converter cable.
Alan Morris
Windows Printing Team
Search the Microsoft Knowledge Base here:
http://support.microsoft.com/search/?adv=1
"aelover77" <guest@xxxxxx-email.com> wrote in message
news:7c52c68d3fc27679e94ae69ac5fdc3ef@xxxxxx-gateway.com...
> trilled about!
> got nothing.
> [image:
> http://img.photobucket.com/albums/v3.../102_2688.jpg][image:
> http://img.photobucket.com/albums/v3.../102_2682.jpg]
> [image:
> http://img.photobucket.com/albums/v3.../102_2684.jpg]
> [image:
> http://img.photobucket.com/albums/v3.../102_2686.jpg][image:
> http://img.photobucket.com/albums/v3.../102_2687.jpg][image:
> aelover77
Old 03-06-2009   #3 (permalink)
Vista Home Premium
I no I don't have a parallel port on the pc is it hard to do what's the difference
Old 03-06-2009   #4 (permalink)
Tom Ferguson
http://www.mysterybyte.com/index.htm...e=sidepart.htm
news:39a4d863e163902b16dc19262a3a6520@xxxxxx-gateway.com...
> difference
> aelover77
Old 03-06-2009   #5 (permalink)
Vista Home Premium
I guess my question is what's the difference in parallel to parallel to USB parallel
Old 03-06-2009   #6 (permalink)
Tom Ferguson
I am not sure of the context in which you expect an answer. So, let me put
it this way:
The engineers who developed the Panasonic XK 2123 printer designed it for a
particular set of hardware which was described by a well-formulated,
well-described specification. It was designed to connect to a(n IBM-type) PC
using a particular connector and using a protocol which is covered by the
IEEE 1284 specification. It is often referred to as a Centronics port,
particularly in older literature. From this follows the suggestion to
install a card with a parallel port in your computer if it now does not have
one. Also, from this follows the suggestion to set the BIOS in the computer
to SPP. This is what the printer was engineered to use.
If you use a USB to parallel converter, it might work without any problem if
you are sure to select a device that is designed to provide output as for a
device expecting IEEE 1284-specified communication. Not all of them do. It
is not always east to determine which of the available devices meet this
requirement. It is not always plainly stated in the product description.
Sometimes you have to 'dig deeper' to get the specification documentation
for the device.
Since the option to install a parallel port card is almost always present
for desktop units, it is the preferred option. Since it is rarely possible
to install such a device on a laptop/notebook/netbook that lacks a parallel
port, either a cardbus to parallel or USB to parallel provide the only
options.
Since we are on the topic: I would also suggest that you use a parallel
printer cable of high quality that is IEEE A certified, not just IEEE
compliant. The possible issues here are the provision of appropriate cable
conductors/connections for full bi-directional support and signal quality
including cross-talk rejection.
Tom
MSMVP 1998-2007
news:c649bfee22b764bdc971f37496530c86@xxxxxx-gateway.com...
> USB parallel
> aelover77
Old 03-09-2009   #7 (permalink)
Alan Morris [MSFT]
I'm stealing this explanation Tom. Good job!
Alan Morris
"Tom Ferguson" <tom.newsgroups@xxxxxx> wrote in message
news:uIyGhgrnJHA.3876@xxxxxx
>it this way:
> a particular set of hardware which was described by a well-formulated,
> PC using a particular connector and using a protocol which is covered by
> the IEEE 1284 specification. It is often referred to as a Centronics port,
> have one. Also, from this follows the suggestion to set the BIOS in the
> computer to SPP. This is what the printer was engineered to use.
> if you are sure to select a device that is designed to provide output as
> for a device expecting IEEE 1284-specified communication. Not all of them
> do. It is not always east to determine which of the available devices meet
> this requirement. It is not always plainly stated in the product
> description. Sometimes you have to 'dig deeper' to get the specification
> documentation for the device.
> parallel port, either a cardbus to parallel or USB to parallel provide the
> only options.
> Tom
> MSMVP 1998-2007
>> USB parallel
>> aelover77
Old 03-09-2009   #8 (permalink)
Tom Ferguson
Feel free! Glad it is useful.
Tom Ferguson
"Alan Morris [MSFT]" <alanmo@xxxxxx> wrote in message
news:ucc$E2OoJHA.500@xxxxxx
> Alan Morris
> rights.
>>it this way:
>> port, particularly in older literature. From this follows the suggestion
>> to install a card with a parallel port in your computer if it now does
>> not have one. Also, from this follows the suggestion to set the BIOS in
>> the computer to SPP. This is what the printer was engineered to use.
>> meet this requirement. It is not always plainly stated in the product
>> possible to install such a device on a laptop/notebook/netbook that lacks
>> a parallel port, either a cardbus to parallel or USB to parallel provide
>> the only options.
>> cable conductors/connections for full bi-directional support and signal
>> quality including cross-talk rejection.
>> Tom
>> MSMVP 1998-2007
>>> USB parallel
>>> aelover77
Vista Can't Print to Win2K shared printer-Test Print disappears fr Vista networking & sharing
Deleted Printer but icon still there & printer wont auto install & wont print Vista installation & setup
Deleted Printer but icon still there & printer wont auto install & wont print Vista print fax & scan
Deleted Printer but icon still there & printer wont auto install & wont print Vista performance & maintenance
Re: Print Shop won't print using laser printer Vista print fax & scan
