Go Back   Vista Forums > Vista Newsgroups > Vista print fax & scan
Vista - Lexmark X5650 Printer Problem
Old 03-23-2009   #1 (permalink)
Vista Home Premium
I keep getting the following error when I try to print.
Job Status Window Interface has stopped Working. I called Lexmark and they said it was a windows problem. Has anybody had this problem? Is there a fix for it?Thanks
Old 03-23-2009   #2 (permalink)
Alan Morris [MSFT]
Re: Lexmark X5650 Printer Problem
the software is not a Microsoft product. You got the writers of the
software correct the first time.
Did MS make core changes that caused their software to not work on Vista,
that's possible. I'll ping one of the Lexmark testers who work here in
Redmond and see if he has additional information on this software.
Does the document print without the use of the Lexmark Job Status Monitor
software?
Alan Morris
Windows Printing Team
Search the Microsoft Knowledge Base here:
http://support.microsoft.com/search/?adv=1
"r70454ss" <guest@xxxxxx-email.com> wrote in message
news:278aa634a39b2456358e97fd0a2211c6@xxxxxx-gateway.com...
> r70454ss
Old 03-23-2009   #3 (permalink)
Alan Morris [MSFT]
If this was an upgrade from XP the issue might be with the files that were
migrated. Did you already install the drivers from 11/2008?
If not delete the printer, delete the drivers, run any uninstall software
from Lexmark and install the printer once again. Hopefully Lexmark will
respond tomorrow.
Version: Released: File Size: Owner:
1.2.6.2 NOV 13 2008 79.30 MB Lexmark
Alan Morris
> r70454ss
Old 03-24-2009   #4 (permalink)
Alan Morris [MSFT]
I found out from my Lexmark contact this is a known issue when running the
Windows 7 OS. Are you running Win7 or Vista.
If you are running Vista, someone who works for Lexmark is interested in
contacting you.
Alan Morris
"Alan Morris [MSFT]" <alanmo@xxxxxx> wrote in message
news:eKsz0RCrJHA.724@xxxxxx
> respond tomorrow.
> Alan Morris
> rights.
>> r70454ss
Old 03-24-2009   #5 (permalink)
Alan Morris [MSFT]
I just heard again from Lexmark, This issue does indeed occur in Vista.
Alan Morris
news:ejeCaOKrJHA.724@xxxxxx
> contacting you.
> Alan Morris
> rights.
>> were migrated. Did you already install the drivers from 11/2008?
>> respond tomorrow.
>> Alan Morris
>> rights.
>>> r70454ss
Old 03-24-2009   #6 (permalink)
Vista Home Premium
My computer came with Vista installed on it.
Old 03-24-2009   #7 (permalink)
Alan Morris [MSFT]
Lexmark said this happens on x64 machines. I'll assume you have the 64bit
OS installed.
Alan Morris
news:d96e1a97d58f312dcd825cc4df0a40c5@xxxxxx-gateway.com...
> r70454ss
Old 03-24-2009   #8 (permalink)
Vista Home Premium
My computer is 32 bit
Old 03-25-2009   #9 (permalink)
Alan Morris [MSFT]
Okay I'll update the Lexmark gang. They had one other question. They said
they have only seen the issue on Windows 7 and Vista SP2. Did you install
one of the Release Candidate SP2 builds?
Lexmark said they have to run the application in compatibility mode. They
did not explain further.
Alan Morris
news:b671d27b41712f0746bc15bf9041b667@xxxxxx-gateway.com...
> r70454ss
Old 03-26-2009   #10 (permalink)
Vista Home Premium
No I have SP1 installed
Printer Problem with Lexmark 6200 Vista hardware & devices
Lexmark Z515 Printer Sharing Problem Vista print fax & scan
Problem installing Lexmark x4650 - error 0x000006be, Print Spooler, Add Printer Vista print fax & scan
Lexmark Printer / Error problem communicating with printer Vista print fax & scan
lexmark printer problem Vista General
