ip4200: Vista Home Basic Fails, but Home premium works
  1. #1
    Newbie
    Vista Home Basic
    Local Time: 05:39 AM
    I have a Canon iP4200 which will NOT work on Vista Home BASIC desktop, but will work on my laptop which has Vista Home PREMIUM.
    The Home Basic is a clean install, virgin hard drive, new computer, etc.
    Vista Home Basic FAIL:
    -Ran setup file iP4200vst200ej.exe from Canon support site
    -Connected usb from printer to computer
    -powered on printer
    -Vista recognizes it as ip4200 and says it is ready
    -Print test page – printer makes some noise like it is going to start ,but fails and shows “An error has occurred when printing
    the following print job. Click Cancel to stop printing. Job: Test Page”
    PRINT SERVER PROPERTIES/Driver Properties:
    Language Monitor: Canon BJ Language Monitor iP4200
    Help file: CNMMH78.CHM
    Config file: CNMUI78DLL
    Data file: CNMCP78.dll
    Driver file: CNMDR78.dll
    Dependent file: CNMLR78.dll
    Dependent file: CNMCB78.dll
    ETC…. with CNM*.dlls
    HERE'S WHAT WORKS on my laptop:
    Vista Home PREMIUM
    Connected usb to computer
    Powered on Printer
    Vista recognizes it correctly and it works
    Language Monitor: BJ Language Monitor 3_3
    Help file: Unidrv.hlp
    Config file: Unidrvui.dll
    Data fie: cnb_0260.gpd
    Driver file: unidrv.dll
    Depenendent file: cnb_260.dll
    Dependent file: cnbjop78.dll
    Etc….. with CNB*.dlls, NOT CNM*.dlls
    so can I manually somehow change the config on the Vista Home Basic computer to use the drivers CNB*.dll which work correctly on my laptop, instead of the CNM* files that aren't working?
  2. #2
    Newbie
    Vista Home Basic
      Thread Starter
    Re: ip4200: Vista Home Basic Fails, but Home premium works
    also i have tried copying the set of dll files from Home Premium that work to a folder on the desktop and changing the drivers thru Device Manager, but it wont change them, it will say i already have the most up-to-date installed.
  3. #3
    Alan Morris [MSFT] Guest
    On the machine that works, the drivers and language monitor are those
    included in Vista.
    Go ahead and install the driver manually on the basic machine (use Add
    Driver on printers folder, Server Properties (run as administrator)
    Alan Morris
    Windows Printing Team
    Search the Microsoft Knowledge Base here:
    http://support.microsoft.com/search/?adv=1
    "wowjimi" <guest@xxxxxx-email.com> wrote in message
    news:148125d2439d3ad58c612824667e9c4e@xxxxxx-gateway.com...
    > wowjimi
  4. #4
    Newbie
    Vista Home Basic
      Thread Starter
    no - it wouldnt let me manually point to old drivers to install, it would say the present ones are most up-to-date.
    Since it is a new computer install, (not much to redo) i just started over with reinstalling vista clean. After vista only, the printer worked fine using vistas drivers.
    THen after installing the motherboard drivers and vga drivers, etc, then openoffice, it went back to the same problem. Now i can plug it in and it doesnt even show a popup that a USB device has connected. Printer still works fine on the laptop. And at least USB mouse works fine on the desktop.
    SO i will start fresh again, do a step by step trial, and see what is causing the conflict. (i updated the motherboard bios by the way and it made no difference.)
    Long story short = its not vista its my new motherboard setup SOMEWHERE...
    thanks for trying to help.
  5. #5
    Newbie
    Vista Home Basic
      Thread Starter
    ok the culprit was a driver packaged within about 10 drivers that are part of the ATI video chipset CATALYST update. I unchecked and didnt install AMD USB FILTER DRIVER 1.0.6.0. Now everything works fine.
ip4200: Vista Home Basic Fails, but Home premium works problems?
I need help with an upgrade from home vista home basic to premium thecleggs3 Vista installation & setup 1 14 Oct 2009
Windows Vista Home Premium Key Home Basic Discs Dane1976 General Discussion 3 29 Jul 2009
how to upgrade from Vista Home Basic to Home Premium? tempest Vista General 0 05 May 2009
Re: Anytime Upgrade from Vista Home Basic to Home Premium PA Bear [MS MVP] Vista installation & setup 3 31 Oct 2008
Upgrade from Vista Home Basic to Home Premium subrajit Vista General 2 20 Sep 2007
