Go Back   Vista Forums > Vista Newsgroups > Vista print fax & scan
Vista - Problem with Lexmark x2480 scanner
Old 04-10-2009   #1 (permalink)
vista x64 home premium
I think it is ridiculous to have a thread for each printer in view that the problems appear to be similar or even the same. But what do I have to do? I have two computers connected within a home network through the router. Everything worked fine though one works under Windows XP Home with ZoneAlarm firewall and second works under Windows Vista x64 Home Premium with Windows firewall. Then I tried to install the Lexmark X2480 All-in-one printer to the network and it was convenient to me to connect it to the computer with Vista. I have disk with the printer so I did not wait for any problem.
First problem arose even before I tried to connect the printer into network. I could print (not from Microsoft Works and Internet Explorer 8??), copy but I couldn't scan. After some searching with the Google I downloaded new driver for the printer and CleanUp utility for Lexmark printers that was mentioned in another thread on this forum. Now everything worked fine on Vista computer and I started network connection for the printer. And again I can print from the Windows XP computer but I can't scan. When I try I have an window with " The Lexmark 2400 Series printer driver is not installed. Please reinstall your printer".
I reinstalled it several times but in vain. What do I have to do next?
Old 04-11-2009   #2 (permalink)
Cari \(MS-MVP\)
Re: Problem with Lexmark x2480 scanner
Networking scanning is very hit and miss. Really if you need this
capability, you need to get a specialized networkable scanner, Epson make
some, starting at around $1500. I'd say that if you need scanning
capability on more than one PC, get several standalone cheap(ish) scanners
and use them.
Cari (MS-MVP) Printing & Imaging
www.coribright.com/windows
"reggepole" <guest@xxxxxx-email.com> wrote in message
news:24f95051eec66c923109623154a475f5@xxxxxx-gateway.com...
> your printer".
> reggepole
Old 04-12-2009   #3 (permalink)
Chuck
I agree that network scanning & fax has been a problem in general. (And for
a long time, using different win versions)
I do have an Epson workforce 600 multifunction that works OK for scanning
from the network, and, after installing
first as a USB system, then changing to wired or wireless networking, will
also work as via a wireless connection for scanning.
Seems there is some sort of a "bug" in XP and possivbly Vista that prevents
proper recognition of a scanner,
be it an all in one or a standalone networkable scanner. What happens on my
systems is that VueScan cannot detect the scanner
unless it is connected via USB. Once this is completed, the ports can be
played with, and eventually switched to the psuedo port
used for a networked scanner/all in one. Once VueScan sees the scanner,
windows built in scanner
related functions may or may not also work, seems to be scanner vendor/model
dependent.
"Cari (MS-MVP)" <newsgroups@xxxxxx> wrote in message
news:74d4luF12qpeiU2@xxxxxx
> and use them.
>> your printer".
>> reggepole
Lexmark X2480 install problem (Vista Ultimate). Vista print fax & scan
Lexmark X2480 Vista print fax & scan
Lexmark X2480 Vista hardware & devices
my lexmark 1200 series printer and scanner does not work! Vista print fax & scan
SCANNER LEXMARK X215 Vista print fax & scan
