HP laserjet 2605DN Printing problem
  1. #1
    Newbie
    Vista Ultimate x64
    Local Time: 03:00 AM
    Setup
    Vista Ultimate x64
    Can someone help me out I have the following printer HP color laserjet 2605dn
    and it won't let me print in duplex mode
    looked on Hp web site for installation drivers and found nothing, then I found this file EZInstall, but It can't find my printer on the network.
    Can someone help me out or point me in the right direction so I can print in duplex mode.
    Thanks
  2. #2
    David Guest
    Re: HP laserjet 2605DN Printing problem
    "Navop" <guest@xxxxxx-email.com> wrote in message
    news:613451766403144c3d821450ff882696@xxxxxx-gateway.com...
    > Setup
    > Vista Ultimate x64
    > color laserjet
    > 2605dn
    > nothing, then
    > on the
    > network.
    > so I can
    > Thanks
    > Navop
    I have exactly the same setup and HP does have a Vista 64
    driver on their site. It is just the driver without all of
    the other stuff. I use it and it works fine.
    David
  3. #3
    David Guest
    "David" <someone@xxxxxx> wrote in message
    news:ugtH2T9uJHA.3816@xxxxxx
    >> Setup
    >> Vista Ultimate x64
    >> color laserjet
    >> 2605dn
    >> nothing, then
    >> on the
    >> network.
    >> direction so I can
    >> Thanks
    >> Navop
    > David
    Replying to my own post; The driver is named:
    clj2605-PCL6-pnp-winv64-ww.exe. Run the file and it will
    unzip into a folder on your hard drive and start
    installation, It the install fails, use the add printer
    dialog and at the appropriate time select 'have disk' and
    point it to that folder that was created. If the printer is
    already installed you can use the update driver to
    accomplish the same thing.
    David
  4. #4
    Newbie
    Vista Ultimate x64
      Thread Starter
    Sorry forgot to mention I'm using network cable, the printer is plugged into a router.
    Looked at the driver you mentioned and its for the usb connection.
    "Use this software for first time USB installations only. Do NOT attach USB cable until prompted by the installation program. The driver contained in this download package is the PCL 6 driver for Windows XP x64 Edition."
    Will looked around for network drivers.
    Thanks
    Navop
  5. #5
    David Guest
    news:fe020996d32b587689ef0864fab93ea9@xxxxxx-gateway.com...
    > printer is plugged
    > into a router.
    > connection.
    > Do NOT attach
    > driver
    > Windows XP
    > x64 Edition."
    > Thanks
    > Navop
    > Navop
    Use the 'add (a network) printer' method I described with
    this same driver and all should work. The USB note applies
    to running the built-in setup routine.
    David
  6. #6
    erintom Guest
    I brought a Toshiba laptop with Vista Ultimate 64 bit to the office and
    cannot get a networked HP2065 printer to work. I downloaded and
    installed the software mentioned above but the laptop cannot find the
    printer. HP is no help as I am 6 months out of warranty but I am amazed
    that they do not support this issue on their web site. Any help would be
    appreciated. Thank you.
    erintom
    erintom's Profile: http://forums.techarena.in/members/96801.htm
    View this thread: http://forums.techarena.in/vista-print-fax/1159766.htm
  7. #7
    Cari \(MS-MVP\) Guest
    You should be able to tell Vista where the printer is by telling it the
    TCP/IP address of the printer as its location, as in
    \\123.123.123.123
    Cari (MS-MVP) Printing & Imaging
    www.coribright.com/windows
    "erintom" <erintom.3rsf7a@xxxxxx> wrote in message
    news:erintom.3rsf7a@xxxxxx
    > erintom
HP laserjet 2605DN Printing problem problems?
Printing to HP LaserJet 1300 2120smak Vista print fax & scan 9 26 Mar 2010
Printing blank pages Windows Vista - HP LaserJet 4 Plus Jasia Abush Vista General 2 10 Aug 2008
printing to HP laserjet 1012 on home network Cpt Falcon Vista print fax & scan 3 04 Feb 2008
USB Printing stopped working with LaserJet 1100 julian Vista hardware & devices 3 03 Aug 2007
Laserjet 5/5M duplex printing doesn't work Denis Molony Vista hardware & devices 2 09 Feb 2007
