| Vista Home Premium | Installation problem with HP printer Hi, Today I purchased an HP Photosmart C7280 and I can't get the software installed on my laptop, which runs Vista Home Premium 32-bit. I've seen this same problem posted elsewhere, but none of the advice so far has fixed it for me. I've also done everything that HP suggests in their troubleshooting section. HELP! The software loads to about 94% overall progress, then I get a Fatal Error message saying that "The installer has encountered an unexpected error installing this package. The error code is 2203. It then tells me to search on HP's Web site for "Fatal Error" and either "MSI.Software_Min," "MSI.webreg" or "MSI.GPBaseservice3." I tried installing the latest driver from HP, and that didn't fix it. Can anyone help? I've already wasted the better part of an afternoon on this and it's been extremely frustrating. Thanks. Last edited by sunds; 04-22-2009 at 07:22 PM.. |
| | Re: Installation problem with HP printer Did you try the solution(s) on HP's website: http://h10025.www1.hp.com/ewfrf/wc/d...name=c00459898 Another thing to try is right clicking on the software package you downloaded from HP and selecting "Run as Administrator". http://search.hp.com/query.html?cc=u...03+c7200&la=en As you can see, you're not alone in this issue.... but HP seem unable or unwilling to solve it for most folks. I'd suggest if you don't want to spend more time on this problem, return the unit and get a Canon or Epson multifunction unit. -- Cari (MS-MVP) Printing & Imaging www.coribright.com/windows "sunds" <guest@xxxxxx-email.com> wrote in message news:ffe5621878dc57b5a66280f3e7ca775e@xxxxxx-gateway.com... Quote: > > Hi, > > Today I purchased an HP Photosmart C7280 and I can't get the software > installed on my laptop. I've seen this same problem posted elsewhere, > but none of the advice so far has fixed it for me. I've also done > everything that HP suggests in their troubleshooting section. HELP! > > The software loads to about 94% overall progress, then I get a Fatal > Error message saying that "The installer has encountered an unexpected > error installing this package. The error code is 2203. It then tells > me to search on HP's Web site for "Fatal Error" and either > "MSI.Software_Min," "MSI.webreg" or "MSI.GPBaseservice3." > > I tried installing the latest driver from HP, and that didn't fix it. > > Can anyone help? I've already wasted the better part of an afternoon > on this and it's been extremely frustrating. > > Thanks. > > > -- > sunds |
| Problem with Dell printer after installation of Vista SP2 (printer prints an extra page) | Vista General | |||
| Help - Printer Installation Problem | Drivers | |||
| Bluetooth Printer Installation Problem | Vista installation & setup | |||
| Printer installation | Vista hardware & devices | |||
| Lexmark Printer / Error problem communicating with printer | Vista print fax & scan | |||
