| | Brother HL-2035 Laser Monochrome will not print I have just installed the above printer. All appears to be Ok except that when I try to print nothing happens. Opening the printer window there is a comment in the status field saying 'error'. Restarting print ends with same error state. Device Manager shows device is working. Other printer Canon ip2500 OK, changed cable etc no change. Vista 32 bit + SP1, Vaio laptop. Any ideas? Cheers Peter |
| | Re: Brother HL-2035 Laser Monochrome will not print What type of cable are you using to connect the printer to the computer? -- Alan Morris Windows Printing Team Search the Microsoft Knowledge Base here: http://support.microsoft.com/search/?adv=1 This posting is provided "AS IS" with no warranties, and confers no rights. "Westperson" <westpeople2006@xxxxxx> wrote in message news:9B43CD69-68F1-4CFD-98F9-8C5A723DE13C@xxxxxx Quote: >I have just installed the above printer. All appears to be Ok except that >when I try to print nothing happens. Opening the printer window there is a >comment in the status field saying 'error'. Restarting print ends with same >error state. Device Manager shows device is working. > > Other printer Canon ip2500 OK, changed cable etc no change. > > Vista 32 bit + SP1, Vaio laptop. > > Any ideas? > > Cheers Peter |
| | Re: Brother HL-2035 Laser Monochrome will not print It is a USB connection for both printers. When I plug it into the PC it seems to find it is a new device and installs the DD driver again, which shows as copy 1 in the printer list. I did get it to print once yesterday (test page) but today it just says Error - Printing is the status column. I have to delete the entry (twice) to clear the queue. I have had issues with the Print Spooler dying on start-up for some long time but after a number of failures (varies from 0-5) all seems fine and the original printer has always worked without problems. Peter "Alan Morris [MSFT]" <alanmo@xxxxxx> wrote in message news:Oeh5qIM2JHA.480@xxxxxx Quote: > What type of cable are you using to connect the printer to the computer? > > -- > Alan Morris > Windows Printing Team > Search the Microsoft Knowledge Base here: > http://support.microsoft.com/search/?adv=1 > > This posting is provided "AS IS" with no warranties, and confers no > rights. > > "Westperson" <westpeople2006@xxxxxx> wrote in message > news:9B43CD69-68F1-4CFD-98F9-8C5A723DE13C@xxxxxx Quote: >>I have just installed the above printer. All appears to be Ok except that >>when I try to print nothing happens. Opening the printer window there is a >>comment in the status field saying 'error'. Restarting print ends with >>same error state. Device Manager shows device is working. >> >> Other printer Canon ip2500 OK, changed cable etc no change. >> >> Vista 32 bit + SP1, Vaio laptop. >> >> Any ideas? >> >> Cheers Peter > |
| brother MFC-9600 vista 64 print drivers not working | Vista print fax & scan | |||
| Brother MFC 6800 and Vista will not print. | Vista print fax & scan | |||
| can not connect to a network printer brother laser printer | Vista networking & sharing | |||
| Re: Print Shop won't print using laser printer | Vista print fax & scan | |||
| RE: Generic laser print drivers | Vista print fax & scan | |||
