brother mfc-640cw problems
  1. #1
    Newbie
    vista ultimate
    Local Time: 11:52 AM
    i have a new system which is the ultimate and although my brother printer will work, the system will lock up on start up. i have to unplug the usb on start up or the system will lock up on the dell logo screen.
  2. #2
    Alan Morris [MSFT] Guest
    Re: brother mfc-640cw problems
    configure the BIOS for the USB ports. See if another setting allows the
    boot. Most likely the new system is USB 2. If the printer is more than 5
    years old it most likely only supports USB 1 which might be the conflict.
    Also make sure you have all the USB patches for Vista. If you are running
    SP2 you should be good.
    Alan Morris
    Windows Printing Team
    Search the Microsoft Knowledge Base here:
    http://support.microsoft.com/search/?adv=1
    "betheredge" <guest@xxxxxx-email.com> wrote in message
    news:5479f9ac8cef8bcce7939a44443039b3@xxxxxx-gateway.com...
    > screen.
    > betheredge
  3. #3
    Newbie
    ultimate x64
    Local Time: 04:52 AM
    i have an mfc 640 brother printer & i am able to get the control panel up & email/scan, when finished it will not open the windows mail, to which file do i connect it with, because i tryed many & will not work
  4. #4
    Chuck Guest
    On 4/29/2010 5:46 AM, meta1 wrote:
    > i have an mfc 640 brother printer& i am able to get the control panel
    > up& email/scan, when finished it will not open the windows mail, to
    > which file do i connect it with, because i tryed many& will not work
    As I remember, that MFP is an older device, and might have worked with
    outlook express and/or outlook. Thunderbird is also a possibility.
    I gave mine away over a year ago, due to various problems--
    Slow, uses too much ink at a high price, feeder misfeeds, and so forth.
Scanner install problems Brother MFC-210C truckergirl Vista print fax & scan 0 22 Nov 2008
Brother HL-1440 shared printer problems frojoy Drivers 0 23 Aug 2008
VISTA is like BIG BROTHER! Dek Vista General 12 31 Dec 2007
Oh brother dubya Vista General 8 04 Dec 2007
brother MFC 440-CN raccoonrick Vista print fax & scan 1 14 May 2007
