Go Back   Vista Forums > Vista Newsgroups > Vista print fax & scan
Vista - Lexmark Printer / Error problem communicating with printer
Old 10-23-2006   #1 (permalink)
David Bolsega
I have a Lexmark Printer E3300 series. I am having difficultly getting the
computer to communicate with the printer. What suggestions are out there to
assit?
Thank you,
Lexmark X5650 Printer Problem Vista print fax & scan
Problem installing Lexmark x4650 - error 0x000006be, Print Spooler, Add Printer Vista print fax & scan
Printer not communicating Vista print fax & scan
pc and printer not communicating Vista print fax & scan
lexmark printer problem Vista General
