Go Back   Vista Forums > Vista Newsgroups > Vista print fax & scan
Vista - Problems with the HP 5700 series printer.
Old 10-29-2006   #1 (permalink)
Theo
Hi all,
I have a HP Deskjet 5774 printer, connected to a workstation on USB and
shared on the network.
When connecting the printer to my Vista RC1 Ultimate workstation, installing
goes well. But when i try to make a testprint the printer prints mirrored.
Allso the prints from Word 2007 Beta are mirrored on the paper.
Trying to print from other workstations (XP) works fine. Does anybody have
an idea what could be the problem?
Thanks
Theo
Old 10-29-2006   #2 (permalink)
Theo
RE: Problems with the HP 5700 series printer.
Forgot to mention: printer is installed with the "HP Deskjet 5700 Series
Printer drivers" and VISTA Pre-RC1 Ultimate is running on "Microsoft Virtual
PC 2007".
Thanks
Theo
"Theo" wrote:
> Hi all,
> Thanks
> Theo
HP Printer PSC 1500 series Vista print fax & scan
Vista & HP All In One Printer C7100 Series Vista print fax & scan
Hp LaserJet Printer, 1300 series Vista print fax & scan
HP Series D Printer Vista print fax & scan
HP 2500 series printer Vista General
