Go Back   Vista Forums > Vista Newsgroups > Vista print fax & scan
Vista - Lexmark z705 test print but won't print
Old 08-20-2009   #1 (permalink)
vista home premium
I try everything i can. I re-intalled the driver. check the cable with no luck. It will print a test page fine, but will not print documents from msworks. ANY HELP WOULD BE APPRICIATED
Old 08-20-2009   #2 (permalink)
vista home premium
By the way there is no error message. but it's not in the printing spool either
Old 08-20-2009   #3 (permalink)
Cari \(MS-MVP\)
Re: Lexmark z705 test print but won't print
Will it print from ANY application? Paint for example? Notepad? Wordpad?
Cari (MS-MVP)
Windows Technologies - Printing & Imaging
http://www.coribright.com/windows
"jagman319" <guest@xxxxxx-email.com> wrote in message
news:2323e56592a613ebb0159eb8c2571d4a@xxxxxx-gateway.com...
> jagman319
unable to print on lexmark Vista print fax & scan
Vista Can't Print to Win2K shared printer-Test Print disappears fr Vista networking & sharing
Trying to print on Lexmark X5260 Vista print fax & scan
Lexmark X1180 does not print Vista General
Lexmark 6100 Series Won't Print Vista print fax & scan
