Go Back   Vista Forums > Vista Newsgroups > Vista print fax & scan
Vista - Problems connecting to Shared HP Deskjet 932C Printer
Old 09-30-2009   #1 (permalink)
Windows Vista Home Premium 64bit
Need some possible insight into finding a solution for a printer problem.
I'm trying to connect to a printer shared over a home network. Here's some of the specifics (will provide more if needed/asked for).
Printer HP Deskjet 932C that is physically hooked to a generic home built computer running Windows XP.
There are two laptops that I am currently trying to connect so that they can print directly to this printer via the home network that all laptop the first laptop is a
Toshiba running Windows Vista Home Premium 32bit w/service pack 1
the other is an
ASUS running Windows Vista Home Premium 64bit w/service pack 1
I've already been to and searched HP's site for an appropriate driver but there is no Vista drivers for this printer listed on their site. HP states that the there is no Vista printer driver for this printer and lists a work around using the basic driver in Vista. Problem with their work around is that its for physically hooking a the printer up via USB/Parallel and I'm trying to do it via my home network. I've looked through out the following folder (C:\Windows\System32\DriverStore\FileRepository\ ) to try to find the right driver but can't figure out which one to use.
Any ideas or work arounds?
Old 09-30-2009   #2 (permalink)
Alan Morris [MSFT]
Re: Problems connecting to Shared HP Deskjet 932C Printer
Most likely the print driver name on XP is not the same name for the driver
included in Vista.
You will need to create an SMB (server messaging block) connection rather
than an RPC connection to the device. This is basically like printing the
job to file and copying the file to \\XPmachine\printer. For simplicity
make sure the printer share name does not contain spaces.
Add
Local Printer
Create Local Port in the format \\XPmachine\printer
Select the driver included in Vista from the list.
Next...
Finish
Alan Morris
Windows Printing Team
Search the Microsoft Knowledge Base here:
http://support.microsoft.com/search/?adv=1
"mapanggulo" <guest@newsgroup-email.com> wrote in message
news:19618a0a9e47a43c6f80102db64116a9@newsgroup-gateway.com...
> problem.
> the other is an
> mapanggulo
connecting to shared printer in vista Vista print fax & scan
Connecting to shared printer Vista print fax & scan
connecting to shared printer Vista networking & sharing
Connecting to network/shared printer Vista print fax & scan
Connecting to a printer shared on XP from Vista Vista General
