| | Using a script to set the default printer at start up after adding it How do I set the default printer using a batch file? Due to problems with a win98se printer share that ONLY happens with Vista 64 HP, I need to reinstall the printer every time I reboot. With help in previous posts, I have the following technically two-line batch file so far: rundll32 printui.dll,PrintUIEntry /dl /n "hp812c" /c\\GATEWAY rundll32 printui.dll,PrintUIEntry /if /b "HP812c" /c\\GATEWAY /f "%windir%\inf\ntprint.inf" /r "\\Slickswintel\hp812c" /m "HP DeskJet 812C" I need a final line to set the newly created HP812C to be the default printer, but can't figure out how to do so from the help file I get from rundll32.printui.dll.PrintUIEntry /? Could somebody please propose what the command should look like? This is my first ever attempt at scripting printer management. The printer is shared as hp812c on a computer called slickswintel that's been happily running win98SE for a decade. The Vista 64 home premium computer is called gateway since I feared that slicksgateway was too long and was why the win98se machine crashed when trying to access the gateway shares. Turns out I was wrong, but never changed it back... |
| | Re: Using a script to set the default printer at start up after adding it use prnmngr.vbs in system32\printing_admin_scripts\en-us to set the default printer. You can copy this file to system32 so it's in the path. -- Alan Morris Windows Printing Team Search the Microsoft Knowledge Base here: http://support.microsoft.com/search/?adv=1 This posting is provided "AS IS" with no warranties, and confers no rights. "SlickRCBD" <slickrcbdnews@newsgroup> wrote in message news:861aa19b-8076-4f97-8304-45999313a51b@newsgroup Quote: > How do I set the default printer using a batch file? Due to problems > with a win98se printer share that ONLY happens with Vista 64 HP, I > need to reinstall the printer every time I reboot. With help in > previous posts, I have the following technically two-line batch file > so far: > > > rundll32 printui.dll,PrintUIEntry /dl /n "hp812c" /c\\GATEWAY > rundll32 printui.dll,PrintUIEntry /if /b "HP812c" /c\\GATEWAY /f > "%windir%\inf\ntprint.inf" /r "\\Slickswintel\hp812c" /m "HP DeskJet > 812C" > > > > > I need a final line to set the newly created HP812C to be the default > printer, but can't figure out how to do so from the help file I get > from > rundll32.printui.dll.PrintUIEntry /? > > > Could somebody please propose what the command should look like? This > is my first ever attempt at scripting printer management. The printer > is shared as hp812c on a computer called slickswintel that's been > happily running win98SE for a decade. The Vista 64 home premium > computer is called gateway since I feared that slicksgateway was too > long and was why the win98se machine crashed when trying to access the > gateway shares. Turns out I was wrong, but never changed it back... |
| Adding a hotfix from the login script | VB Script | |||
| XP desktop printer networked to VISTA laptop - adding printer error | Vista print fax & scan | |||
| Adding attributes to Richard Muellers script | VB Script | |||
| Adding Remote Users to AD via Script | VB Script | |||
| Vista keeps stealing default status from default printer computer | Vista networking & sharing | |||
