Ink Level indicator for Lexmark 5650
  1. #1
    Newbie
    Vista Home 32bit
    Local Time: 02:32 PM
    Hello all,
    I use LEXMARK 5650 and VISTA HOME BASIC 32 bit. After replacement of colour ink cartridge (clone of course...) ink level indicator - ruler - appears with a big questionary mark on it. Also, when I press setup button on the printer and go to ink level settings I see questionary mark "?". (For black ink I get a number, like 32%...). What can I do, e.g. how to tell the system/driver that colour cartridge is FULL and how to get rid of that questionary mark ?
    Please, advise.
  2. #2
    DL Guest
    Re: Ink Level indicator for Lexmark 5650
    Nothing to do with Vista, its a feature of your printer cartridges that have
    a chip in them to identify a none makers cartridge.
    Either buy original cartridges or ones guaranteed to be compliant.
    Or do a google search for a fix
    "vkprivate" <guest@newsgroup-email.com> wrote in message
    news:ff3b2d1257e83659e078b93d6ffe1434@newsgroup-gateway.com...
    > Hello all,
    > Please, advise.
    > vkprivate
  3. #3
    Leroy Guest
    Your issue can be resolved by purchasing "genuine" Lexmark ink
    cartridges and not "clones".
    See:http://www1.lexmark.com/content/en_u...e_always.shtml
    vkprivate wrote:
    > Hello all,
    > Please, advise.
  4. #4
    Newbie
    xp
    Local Time: 01:32 PM
    First try to update your driver and if this will not work then you have to go for OEM cartridges.I think it might be a problem of your cartridge.
    ____________________
    Lexmark Ink Cartridges
Ink Level indicator for Lexmark 5650 problems?
battery level indicator/icon in navigation bar Peter Harrison Vista performance & maintenance 0 31 Dec 2007
offline files indicator and shortcut indicator Robert Premuž Vista General 1 10 Jul 2007
Hp 5650 Deskjet & Vista TJGS Vista print fax & scan 3 26 Apr 2007
Microphone level indicator fluctuates, but no audio can be heard Benjamin G Vista General 7 19 Mar 2007
HP Deskjet 5650 beefyme Vista print fax & scan 7 01 Oct 2006
