| | Vista Ultimate Printer Problem I upgraded my machine from XP Pro to Vista Ultimate and things in the printing department are not going well. I see none of the printers that I had installed previously on my machine so I try to Add Printer and I get the error message "Windows can't open Add Printer Operation could not be completed (Error 0x000006be)" I am not sure what is causing this problem but when it does this the Print Spooler service stops and I have to restart the service. I can't get any printers to install on this machine because I can't ever get in the Add Printer wizard. Please help!! |
| | Re: Vista Ultimate Printer Problem It sounds like the previous driver is causing the spooler service to terminate. Bruce has some value pointers. http://members.shaw.ca/bsanders/CleanPrinterDrivers.htm -- Alan Morris Windows Printing Team Search the Microsoft Knowledge Base here: http://support.microsoft.com/default.aspx?scid=fh;[ln];kbhowto This posting is provided "AS IS" with no warranties, and confers no rights. "Larry Dodd" <larryddodd@comcast.net> wrote in message news:%23iRJmAyPHHA.140@TK2MSFTNGP04.phx.gbl... >I upgraded my machine from XP Pro to Vista Ultimate and things in the >printing department are not going well. I see none of the printers that I >had installed previously on my machine so I try to Add Printer and I get >the error message "Windows can't open Add Printer Operation could not be >completed (Error 0x000006be)" I am not sure what is causing this problem >but when it does this the Print Spooler service stops and I have to restart >the service. I can't get any printers to install on this machine because I >can't ever get in the Add Printer wizard. Please help!! |
| | Re: Vista Ultimate Printer Problem On Tue, 23 Jan 2007 12:56:09 -0600, "Larry Dodd" <larryddodd@comcast.net> wrote: > I upgraded my machine from XP Pro to Vista Ultimate and things in the > printing department are not going well. I see none of the printers that I > had installed previously on my machine so I try to Add Printer and I get the > error message "Windows can't open Add Printer Operation could not be > completed (Error 0x000006be)" I am not sure what is causing this problem but > when it does this the Print Spooler service stops and I have to restart the > service. I can't get any printers to install on this machine because I can't > ever get in the Add Printer wizard. Please help!! Exact same problem here, down to the error code. Local printers don't install either. Jim |
| | Re: Vista Ultimate Printer Problem On Tue, 23 Jan 2007 17:14:33 -0800, "Alan Morris [MSFT]" <alanmo@online.microsoft.com> wrote: > It sounds like the previous driver is causing the spooler service to > terminate. > > Bruce has some value pointers. > > http://members.shaw.ca/bsanders/CleanPrinterDrivers.htm In my case the 0x000006be error is on a clean install of Vista Enterprise, so previous drivers don't pertain. I checked server properties and there are none. The error happens whether adding local or remote printers, and also when viewing the Ports tab in the server properties....I believe it may be related to printer ports. Jim |
| | Re: Vista Ultimate Printer Problem what key entries are in the registry HKLM\SOFTWARE\Microsoft\WindowsNT\CurrentVersion\Print and HKLM\SYSTEM\CurrentControlSet\Control\Print Look for installed printer, drivers, and port monitors -- Alan Morris Windows Printing Team Search the Microsoft Knowledge Base here: http://support.microsoft.com/default.aspx?scid=fh;[ln];kbhowto This posting is provided "AS IS" with no warranties, and confers no rights. "Jim Miller" <yohocoma@yahoo.com> wrote in message news:cf1fr2tqt4tk1o7ggbnt4od0n69rkvpvdh@4ax.com... > On Tue, 23 Jan 2007 12:56:09 -0600, "Larry Dodd" > <larryddodd@comcast.net> wrote: > >> I upgraded my machine from XP Pro to Vista Ultimate and things in the >> printing department are not going well. I see none of the printers that I >> had installed previously on my machine so I try to Add Printer and I get >> the >> error message "Windows can't open Add Printer Operation could not be >> completed (Error 0x000006be)" I am not sure what is causing this problem >> but >> when it does this the Print Spooler service stops and I have to restart >> the >> service. I can't get any printers to install on this machine because I >> can't >> ever get in the Add Printer wizard. Please help!! > > > Exact same problem here, down to the error code. Local printers don't > install either. > > Jim |
| | #6 (permalink) |
| | Re: Vista Ultimate Printer Problem There is nothing under either of these registry keys. I followed all the directions in Bruce's article as well. When the error comes up it is always a different error number. How can I reinstall the spooler service drivers? I also did an upgrade of Vista on top of itself in the hopes that the applications would repair themselves but that had no effect either. What else can I try to get this thing working? "Alan Morris [MSFT]" <alanmo@online.microsoft.com> wrote in message news:%23LrJBn%23PHHA.2468@TK2MSFTNGP06.phx.gbl... > what key entries are in the registry > > HKLM\SOFTWARE\Microsoft\WindowsNT\CurrentVersion\Print > and > HKLM\SYSTEM\CurrentControlSet\Control\Print > > Look for installed printer, drivers, and port monitors > > -- > Alan Morris > Windows Printing Team > Search the Microsoft Knowledge Base here: > http://support.microsoft.com/default.aspx?scid=fh;[ln];kbhowto > > This posting is provided "AS IS" with no warranties, and confers no > rights. > > "Jim Miller" <yohocoma@yahoo.com> wrote in message > news:cf1fr2tqt4tk1o7ggbnt4od0n69rkvpvdh@4ax.com... >> On Tue, 23 Jan 2007 12:56:09 -0600, "Larry Dodd" >> <larryddodd@comcast.net> wrote: >> >>> I upgraded my machine from XP Pro to Vista Ultimate and things in the >>> printing department are not going well. I see none of the printers that >>> I >>> had installed previously on my machine so I try to Add Printer and I get >>> the >>> error message "Windows can't open Add Printer Operation could not be >>> completed (Error 0x000006be)" I am not sure what is causing this problem >>> but >>> when it does this the Print Spooler service stops and I have to restart >>> the >>> service. I can't get any printers to install on this machine because I >>> can't >>> ever get in the Add Printer wizard. Please help!! >> >> >> Exact same problem here, down to the error code. Local printers don't >> install either. >> >> Jim > > |
| | #7 (permalink) |
| | Re: Vista Ultimate Printer Problem Has anyone found out anything about this problem. I have obtained the spoolsv.exe from another machine to try and replace the current one on my machine but it says i need to have permissions to do this. I have logged on as the administrator and everything else that I can think of but still nothing. Anyone who can help would be appreciated. "Larry Dodd" <larryddodd@comcast.net> wrote in message news:%23iRJmAyPHHA.140@TK2MSFTNGP04.phx.gbl... >I upgraded my machine from XP Pro to Vista Ultimate and things in the >printing department are not going well. I see none of the printers that I >had installed previously on my machine so I try to Add Printer and I get >the error message "Windows can't open Add Printer Operation could not be >completed (Error 0x000006be)" I am not sure what is causing this problem >but when it does this the Print Spooler service stops and I have to restart >the service. I can't get any printers to install on this machine because I >can't ever get in the Add Printer wizard. Please help!! |
| | #8 (permalink) |
| | Re: Vista Ultimate Printer Problem Has anyone found an answer to this problem. I do not want to start from scratch if at all possible. "Larry Dodd" <larryddodd@comcast.net> wrote in message news:%23iRJmAyPHHA.140@TK2MSFTNGP04.phx.gbl... >I upgraded my machine from XP Pro to Vista Ultimate and things in the >printing department are not going well. I see none of the printers that I >had installed previously on my machine so I try to Add Printer and I get >the error message "Windows can't open Add Printer Operation could not be >completed (Error 0x000006be)" I am not sure what is causing this problem >but when it does this the Print Spooler service stops and I have to restart >the service. I can't get any printers to install on this machine because I >can't ever get in the Add Printer wizard. Please help!! |
| | #9 (permalink) |
| | Re: Vista Ultimate Printer Problem Alan, as you're in the Windows Printing Team here is a related problem/issue. In my case I have a HP 3015 all-in-one printer on a W2003 Server. I can see the networked printers from Vista (64-bit Enterprise version) but can't install them. I did search the KB for "install printer drivers" in the Vista Enterprise KB and read about Kernel vs. User mode drivers. I can accept this. HP says the driver is "in" Vista, and if I plug the printert into the Vista nmachine it detects the printer and installs it! Great! But I can not manually install the driver from Vista and use it with the exact same printer on the network! It is on the DVD somewhere but there is no way, given how the DVD is set up, to get at it! I have the drivers installed in Vista from when I connected the printer directly, but can't tell Vista to use them to work with the printer on the network! Talk about frustrating! There IS a driver that supports the printer, but apparently it can't be gotten at! Suggestions? "Alan Morris [MSFT]" wrote: > It sounds like the previous driver is causing the spooler service to > terminate. > > Bruce has some value pointers. > > http://members.shaw.ca/bsanders/CleanPrinterDrivers.htm > > -- > Alan Morris > Windows Printing Team > Search the Microsoft Knowledge Base here: > http://support.microsoft.com/default.aspx?scid=fh;[ln];kbhowto > > This posting is provided "AS IS" with no warranties, and confers no rights. > > "Larry Dodd" <larryddodd@comcast.net> wrote in message > news:%23iRJmAyPHHA.140@TK2MSFTNGP04.phx.gbl... > >I upgraded my machine from XP Pro to Vista Ultimate and things in the > >printing department are not going well. I see none of the printers that I > >had installed previously on my machine so I try to Add Printer and I get > >the error message "Windows can't open Add Printer Operation could not be > >completed (Error 0x000006be)" I am not sure what is causing this problem > >but when it does this the Print Spooler service stops and I have to restart > >the service. I can't get any printers to install on this machine because I > >can't ever get in the Add Printer wizard. Please help!! > > > |
| | #10 (permalink) |
| | Re: Vista Ultimate Printer Problem HP changed a bunch of the driver names in Vista. When the driver name is different, it's a different driver. When Vista connects to the server it will attempt to use the driver from the server. Here's what you do, since this has been the work around since NT4 times. You need to add a local printer that prints to a local port with the name \\printserver\printshare Bruce has the step by step guide on this. http://members.shaw.ca/bsanders/NetPrinterNoPP.htm -- Alan Morris Windows Printing Team Search the Microsoft Knowledge Base here: http://support.microsoft.com/default.aspx?scid=fh;[ln];kbhowto This posting is provided "AS IS" with no warranties, and confers no rights. "NormD" <mach2@newsgroup.nospam> wrote in message news:4DB59D0E-46F4-4E64-97F3-69A01B6D04CC@microsoft.com... > Alan, as you're in the Windows Printing Team here is a related > problem/issue. > > In my case I have a HP 3015 all-in-one printer on a W2003 Server. I can > see > the networked printers from Vista (64-bit Enterprise version) but can't > install them. I did search the KB for "install printer drivers" in the > Vista > Enterprise KB and read about Kernel vs. User mode drivers. I can accept > this. > > HP says the driver is "in" Vista, and if I plug the printert into the > Vista > nmachine it detects the printer and installs it! Great! But I can not > manually install the driver from Vista and use it with the exact same > printer > on the network! It is on the DVD somewhere but there is no way, given how > the DVD is set up, to get at it! I have the drivers installed in Vista > from > when I connected the printer directly, but can't tell Vista to use them to > work with the printer on the network! Talk about frustrating! There IS a > driver that supports the printer, but apparently it can't be gotten at! > > Suggestions? > > > "Alan Morris [MSFT]" wrote: > >> It sounds like the previous driver is causing the spooler service to >> terminate. >> >> Bruce has some value pointers. >> >> http://members.shaw.ca/bsanders/CleanPrinterDrivers.htm >> >> -- >> Alan Morris >> Windows Printing Team >> Search the Microsoft Knowledge Base here: >> http://support.microsoft.com/default.aspx?scid=fh;[ln];kbhowto >> >> This posting is provided "AS IS" with no warranties, and confers no >> rights. >> >> "Larry Dodd" <larryddodd@comcast.net> wrote in message >> news:%23iRJmAyPHHA.140@TK2MSFTNGP04.phx.gbl... >> >I upgraded my machine from XP Pro to Vista Ultimate and things in the >> >printing department are not going well. I see none of the printers that >> >I >> >had installed previously on my machine so I try to Add Printer and I get >> >the error message "Windows can't open Add Printer Operation could not be >> >completed (Error 0x000006be)" I am not sure what is causing this problem >> >but when it does this the Print Spooler service stops and I have to >> >restart >> >the service. I can't get any printers to install on this machine because >> >I >> >can't ever get in the Add Printer wizard. Please help!! >> >> >> |
| Installation of SamSung CLP-300 Printer on Vista Ultimate | Vista print fax & scan | |||
| Problem with Dell printer after installation of Vista SP2 (printer prints an extra page) | Vista General | |||
| Problem installing Canon printer in Vista Ultimate 64 bit | Vista print fax & scan | |||
| XP Pro x32 cannot print to Vista Ultimate x64 Shared Printer | Vista General | |||
| Printing through VISTA Ultimate - printer offline | Vista print fax & scan | |||
