Go Back   Vista Forums > Vista Newsgroups > Vista print fax & scan
Vista - Need help removing Winfax from Vista
Old 02-02-2007   #1 (permalink)
-=Punkrat=-
I recently upgraded to Vista and want to uninstall Winfax 10
I've downloaded the Norton Removal Tool
It identified my Norton software which I'll remove and only replace
with Norton Anti-Virus 2007, also recently downloaded and installed.
In order to remove Norton 2007 for reinstall I have to first remove
Winfax 10 (it suggests that I remove through add/remove software
option, but it doesn't even show installed after the Vista upgrade.)
Anyone else solve this problem?
Old 02-04-2007   #2 (permalink)
Yuriy Shkolnikov [MSFT]
Re: Need help removing Winfax from Vista
Try this:
http://service1.symantec.com/SUPPORT...98102114161204
Regards,
Yuriy
"-=Punkrat=-" <fale@cheddar.com> wrote in message
news:hpr6s25rhvgdv5319i9326s6gjrh0f3lmd@4ax.com...
Is WinFax Pro 8.0 Vista Compatible? Vista print fax & scan
Vista and Winfax Vista print fax & scan
WinFax for Vista Vista General
WINFAX and Vista Drivers
Winfax Pro & Vista Vista print fax & scan
