br> br> |
| | Thread Tools | Display Modes |
| Guest | Printer problems Vista 64 will not accept additional drivers when setting up a network printer. On my laptop I can install it using "local printer" but when I try and install using "network printer" I get message not suitable driver. The driver worked w/ XP32pro before I got Vista, now it does not work at all. I check the box "x86" (for 32 bit, right?) and nothing. Thanks |
| Guest | Re: Printer problems I guess I'd need some clarification here Is your laptop running Vista x64? Or the server is running Vista x64 and you are trying to connect to it from a laptop running x86 version of the OS ? On a side note, on Vista x64, you can only install signed drivers developed specifically for x64. -- Regards, Yuriy This posting is provided "AS IS" with no warranties, and confers no rights. "dlewis14" <dlewis14@discussions.microsoft.com> wrote in message news:267337D0-7CAB-49B3-8348-C76C956654C0@microsoft.com... > Vista 64 will not accept additional drivers when setting up a network > printer. On my laptop I can install it using "local printer" but when I > try > and install using "network printer" I get message not suitable driver. The > driver worked w/ XP32pro before I got Vista, now it does not work at all. > I > check the box "x86" (for 32 bit, right?) and nothing. > Thanks > |
| Display Modes | |
| printer and other problems | sufferingwithvista | Vista print fax & scan | 1 | 12-10-2007 04:11 PM |
| HP Printer Problems | smtjs | Vista General | 0 | 12-02-2007 11:46 PM |
| RE: printer problems | Don Hubbard | Vista General | 0 | 04-24-2007 12:12 AM |
| printer problems | Vista print fax & scan | 2 | 03-20-2007 12:14 PM | |
| printer problems | Vista General | 0 | 02-14-2007 04:42 AM | |
