| | HP printer with USB will not work with Vista (32/Premium) :? I Have a HP Pavillion 7733 with Vista Home Premium. My printer is a HP LJ1300 which previously has been used on XP. When I plug In on the Vista machine I get the sound - and a new device appears in device properties under IEEE1284.4 devices. The unit is correctly identified as a "HP LaserJet 1300 series (DOT4USB)". However, the printer has not been installed under "Printers". I have then fried to install a std. HP LJ1300 using LPT1: Afterwards I have tried to change the port to Dot4_USB - but there are no Dot4 ports available. After contact with HP support I have downloaded the program "ftp://ftp.hp.com/pub/softlib/software8/COL17364/dj-46093-3/HP_Vista_SF_Ph1.exe"... After installing this program the system reports that the Dot4 ports are installed. But no change. The printer appears under 1284.4 devices - but not under printers - and the only ports available are Local or TCP/IP.. I would very much appreciate any help on this matter. Regards from a frustrated Dane... Troels -- Posted at author's request, using fully moderated http://www.WinForumz.com/Print-Fax-Scan-forum-25.html interface |
| | Re: HP printer with USB will not work with Vista (32/Premium) I don't know if this is a USB or a parallel port connected printer and because it is discontinued the HP website does not give specifications to look up. Which are you using? Have a look at this article on setting up under VISTA: http://h20000.www2.hp.com/bizsupport.../Document.jsp? lang=en&cc=us&taskId=115&prodSeriesId=238320&prodTypeId=18972&prodSerie sId=238320&objectID=c00784183 and in particular what it says about selecting ports. Did you install any software for the printer other than the download you mentioned? Let me know the answers to the questions here about connection and software and we may be able to move on. --------------------------------------------------------------------- It may help other HP Printer users to know that the file you downloaded says in its INF file that it can be used with the following HP printers: LIST OF HP PRINTERS COVERED BY HP FILE: HP_Vista_SF_Ph1.exe "ftp://ftp.hp.com/pub/softlib/software8/COL17364/dj-46093- 3/HP_Vista_SF_Ph1.exe"... ******************************** ;for VISTA 32 bit machine ;******************************** [HP.NT.6.0] ;Pip South Products "HP Photosmart A510 series" = hppa5103.GPD.NT.6.0,USBPRINT\HPPhotosmart_A510_seE03C "HP Photosmart A610 series" = hppa6103.GPD.NT.6.0,USBPRINT\HPPhotosmart_A610_se2FB5 "HP Photosmart A710 series" = hppa7103.GPD.NT.6.0,USBPRINT\HPPhotosmart_A710_seEAE4 "HP Photosmart A430 series" = hppa4303.GPD.NT.6.0,USBPRINT\HPPhotosmart_A430_se670C ;Pip North Products "HP Photosmart D6100 series" = hpp61003.GPD.NT.6.0,USBPRINT\HPPhotosmart_D6100_s4766 "HP Photosmart D7100 series" = hpp71003.GPD.NT.6.0,USBPRINT\HPPhotosmart_D7100_sB962 "HP Photosmart D7300 series" = hpp73003.GPD.NT.6.0,USBPRINT\HPPhotosmart_D7300_s73C1 ;Beagle Product "HP Deskjet D2300 series" = hpp23003.GPD.NT.6.0,USBPRINT\HPDeskjet_D2300_seri856D ;Basset "HP Deskjet D1300 series" = hpp13003.GPD.NT.6.0,USBPRINT\HPDeskjet_D1300_seriBAE2 ;Akita "HP Photosmart D5100 series" = hpp51003.GPD.NT.6.0,USBPRINT\HPPhotosmart_D5100_s0169 ;Chihuahua "HP Photosmart D5060 series" = hpp50603.GPD.NT.6.0,USBPRINT\HPPhotosmart_D5060_s6413 ;Cyclops "HP Photosmart A310 series" = hppa3103.GPD.NT.6.0,USBPRINT\HPPhotosmart_A310_se3FA5 ;Bluetooth "HP Photosmart A510 series BT" = hppa5103.GPD.NT.6.0,BTHPRINT\HPPhotosmart_A510_se8388 "HP Photosmart A610 series BT" = hppa6103.GPD.NT.6.0,BTHPRINT\HPPhotosmart_A610_se9B0 "HP Photosmart A710 series BT" = hppa7103.GPD.NT.6.0,BTHPRINT\HPPhotosmart_A710_se1A0E "HP Photosmart A430 series BT" = hppa4303.GPD.NT.6.0,BTHPRINT\HPPhotosmart_A430_se7EEB "HP Photosmart D6100 series BT" = hpp61003.GPD.NT.6.0,BTHPRINT\HPPhotosmart_D6100_sA2D2 "HP Photosmart D7100 series BT" = hpp71003.GPD.NT.6.0,BTHPRINT\HPPhotosmart_D7100_s1091 "HP Photosmart D7300 series BT" = hpp73003.GPD.NT.6.0,BTHPRINT\HPPhotosmart_D7300_s8375 "HP Photosmart D5100 series BT" = hpp51003.GPD.NT.6.0,BTHPRINT\HPPhotosmart_D5100_sC1D0 "HP Photosmart D5060 series BT"= hpp50603.GPD.NT.6.0,BTHPRINT\HPPhotosmart_D5060_s48DA "HP Photosmart A310 series BT" = hppa3103.GPD.NT.6.0,BTHPRINT\HPPhotosmart_A310_se5F83 --------------------------------------------------------------------- I love some of their product names -- Beagle ..... <g> |
| | Re: HP printer with USB will not work with Vista (32/Premium) Hi again, The printer is a USB device (and works fine using Dot4 under XP). I have installed it on Vista using the same driver. I have read the HP article- but my problem is, that the selection Dot4 USB is not offered under ports, just local and tcp/ip... I have no other printing software installed - just barebone Vista.. Thanks for your help on this.. Reg. Troels "Hugh Wyn Griffith" wrote: > I don't know if this is a USB or a parallel port connected printer and > because it is discontinued the HP website does not give specifications > to look up. Which are you using? > > Have a look at this article on setting up under VISTA: > > http://h20000.www2.hp.com/bizsupport.../Document.jsp? > lang=en&cc=us&taskId=115&prodSeriesId=238320&prodTypeId=18972&prodSerie > sId=238320&objectID=c00784183 > > and in particular what it says about selecting ports. > > Did you install any software for the printer other than the download > you mentioned? > > Let me know the answers to the questions here about connection and > software and we may be able to move on. > > --------------------------------------------------------------------- > > It may help other HP Printer users to know that the file you downloaded > says in its INF file that it can be used with the following HP > printers: > > LIST OF HP PRINTERS COVERED BY HP FILE: HP_Vista_SF_Ph1.exe > > "ftp://ftp.hp.com/pub/softlib/software8/COL17364/dj-46093- > 3/HP_Vista_SF_Ph1.exe"... > > ******************************** > ;for VISTA 32 bit machine > ;******************************** > [HP.NT.6.0] > ;Pip South Products > "HP Photosmart A510 series" = > hppa5103.GPD.NT.6.0,USBPRINT\HPPhotosmart_A510_seE03C > "HP Photosmart A610 series" = > hppa6103.GPD.NT.6.0,USBPRINT\HPPhotosmart_A610_se2FB5 > "HP Photosmart A710 series" = > hppa7103.GPD.NT.6.0,USBPRINT\HPPhotosmart_A710_seEAE4 > "HP Photosmart A430 series" = > hppa4303.GPD.NT.6.0,USBPRINT\HPPhotosmart_A430_se670C > > ;Pip North Products > "HP Photosmart D6100 series" = > hpp61003.GPD.NT.6.0,USBPRINT\HPPhotosmart_D6100_s4766 > "HP Photosmart D7100 series" = > hpp71003.GPD.NT.6.0,USBPRINT\HPPhotosmart_D7100_sB962 > "HP Photosmart D7300 series" = > hpp73003.GPD.NT.6.0,USBPRINT\HPPhotosmart_D7300_s73C1 > > ;Beagle Product > "HP Deskjet D2300 series" = > hpp23003.GPD.NT.6.0,USBPRINT\HPDeskjet_D2300_seri856D > ;Basset > "HP Deskjet D1300 series" = > hpp13003.GPD.NT.6.0,USBPRINT\HPDeskjet_D1300_seriBAE2 > ;Akita > "HP Photosmart D5100 series" = > hpp51003.GPD.NT.6.0,USBPRINT\HPPhotosmart_D5100_s0169 > ;Chihuahua > "HP Photosmart D5060 series" = > hpp50603.GPD.NT.6.0,USBPRINT\HPPhotosmart_D5060_s6413 > ;Cyclops > "HP Photosmart A310 series" = > hppa3103.GPD.NT.6.0,USBPRINT\HPPhotosmart_A310_se3FA5 > > ;Bluetooth > "HP Photosmart A510 series BT" = > hppa5103.GPD.NT.6.0,BTHPRINT\HPPhotosmart_A510_se8388 > "HP Photosmart A610 series BT" = > hppa6103.GPD.NT.6.0,BTHPRINT\HPPhotosmart_A610_se9B0 > "HP Photosmart A710 series BT" = > hppa7103.GPD.NT.6.0,BTHPRINT\HPPhotosmart_A710_se1A0E > "HP Photosmart A430 series BT" = > hppa4303.GPD.NT.6.0,BTHPRINT\HPPhotosmart_A430_se7EEB > "HP Photosmart D6100 series BT" = > hpp61003.GPD.NT.6.0,BTHPRINT\HPPhotosmart_D6100_sA2D2 > "HP Photosmart D7100 series BT" = > hpp71003.GPD.NT.6.0,BTHPRINT\HPPhotosmart_D7100_s1091 > "HP Photosmart D7300 series BT" = > hpp73003.GPD.NT.6.0,BTHPRINT\HPPhotosmart_D7300_s8375 > "HP Photosmart D5100 series BT" = > hpp51003.GPD.NT.6.0,BTHPRINT\HPPhotosmart_D5100_sC1D0 > "HP Photosmart D5060 series BT"= > hpp50603.GPD.NT.6.0,BTHPRINT\HPPhotosmart_D5060_s48DA > "HP Photosmart A310 series BT" = > hppa3103.GPD.NT.6.0,BTHPRINT\HPPhotosmart_A310_se5F83 > > --------------------------------------------------------------------- > > I love some of their product names -- Beagle ..... <g> > > |
| | Re: HP printer with USB will not work with Vista (32/Premium) EUREKA.... fixed it... Here are the details: After installing the HP_Vista_SF_Ph1.exe... some additional drivers for USB were apparently installed. Under Device manager\IEEE1284.4 compatible devices I used Update driver\search driver on this computer\select a driver on this computer (I have a danish system so the terms may be other in US versions.).. On this tab I get 3 choices: 1) HP LaserJet 1300 Series (DOT4USB), 2)Support for DOT4USB printing and 3) Support for USB printing... I selected 2) and restarted... I now get an additional entry under device manager: IEEE1284.4 compatible printer... and on the printer tab I get both the LJ1300 PCL as well as the LJ1300 PS... and they both work fine - on the local USB-port as well as the USB port on my ROLINE 4:1 switch, i.e. I can switch the printer to my 3 PC's... Great. Thanks for helping me out.... |
| | Re: HP printer with USB will not work with Vista (32/Premium) Good news indeed -- some of it sounds familiar although I didn't have to do it myself for my LJ2200d. |
| | #6 (permalink) |
| | Re: HP printer with USB will not work with Vista (32/Premium) Did you follow the instructions at the HP website at : http://h20000.www2.hp.com/bizsupport...rtTaskId=12456 -- Cari (MS-MVP) Windows Technologies - Printing & Imaging http://www.coribright.com/windows "Troels" <none@000.com> wrote in message news:98209_7b26baf7b8d38b85432ea0f88f7e95c8@winforumz.com... > :? > I Have a HP Pavillion 7733 with Vista Home Premium. My printer is a HP > LJ1300 which previously has been used on XP. > When I plug In on the Vista machine I get the sound - and a new device > appears in device properties under IEEE1284.4 devices. The unit is > correctly identified as a "HP LaserJet 1300 series (DOT4USB)". > However, the printer has not been installed under "Printers". > I have then fried to install a std. HP LJ1300 using LPT1: > Afterwards I have tried to change the port to Dot4_USB - but there are > no Dot4 ports available. After contact with HP support I have > downloaded the program > "ftp://ftp.hp.com/pub/softlib/software8/COL17364/dj-46093-3/HP_Vista_SF_Ph1.exe"... > After installing this program the system reports that the Dot4 ports > are installed. But no change. The printer appears under 1284.4 devices > - but not under printers - and the only ports available are Local or > TCP/IP.. > I would very much appreciate any help on this matter. > Regards from a frustrated Dane... > Troels > > -- > Posted at author's request, using fully moderated > http://www.WinForumz.com/Print-Fax-Scan-forum-25.html interface |
| | #7 (permalink) |
| | Re: HP printer with USB will not work with Vista (32/Premium) I just got off the phone with tec support at HP. They tranfered me to the supervisor who told me that Microsoft should have waited to roll ourt Vista untill Hp was able to update their drivers. The drivers will be ready by March 2nd on their site for download. Tec support got 5800 calls today alone. Any lexmark or cannon may take longer. -- Char "Hugh Wyn Griffith" wrote: > I don't know if this is a USB or a parallel port connected printer and > because it is discontinued the HP website does not give specifications > to look up. Which are you using? > > Have a look at this article on setting up under VISTA: > > http://h20000.www2.hp.com/bizsupport.../Document.jsp? > lang=en&cc=us&taskId=115&prodSeriesId=238320&prodTypeId=18972&prodSerie > sId=238320&objectID=c00784183 > > and in particular what it says about selecting ports. > > Did you install any software for the printer other than the download > you mentioned? > > Let me know the answers to the questions here about connection and > software and we may be able to move on. > > --------------------------------------------------------------------- > > It may help other HP Printer users to know that the file you downloaded > says in its INF file that it can be used with the following HP > printers: > > LIST OF HP PRINTERS COVERED BY HP FILE: HP_Vista_SF_Ph1.exe > > "ftp://ftp.hp.com/pub/softlib/software8/COL17364/dj-46093- > 3/HP_Vista_SF_Ph1.exe"... > > ******************************** > ;for VISTA 32 bit machine > ;******************************** > [HP.NT.6.0] > ;Pip South Products > "HP Photosmart A510 series" = > hppa5103.GPD.NT.6.0,USBPRINT\HPPhotosmart_A510_seE03C > "HP Photosmart A610 series" = > hppa6103.GPD.NT.6.0,USBPRINT\HPPhotosmart_A610_se2FB5 > "HP Photosmart A710 series" = > hppa7103.GPD.NT.6.0,USBPRINT\HPPhotosmart_A710_seEAE4 > "HP Photosmart A430 series" = > hppa4303.GPD.NT.6.0,USBPRINT\HPPhotosmart_A430_se670C > > ;Pip North Products > "HP Photosmart D6100 series" = > hpp61003.GPD.NT.6.0,USBPRINT\HPPhotosmart_D6100_s4766 > "HP Photosmart D7100 series" = > hpp71003.GPD.NT.6.0,USBPRINT\HPPhotosmart_D7100_sB962 > "HP Photosmart D7300 series" = > hpp73003.GPD.NT.6.0,USBPRINT\HPPhotosmart_D7300_s73C1 > > ;Beagle Product > "HP Deskjet D2300 series" = > hpp23003.GPD.NT.6.0,USBPRINT\HPDeskjet_D2300_seri856D > ;Basset > "HP Deskjet D1300 series" = > hpp13003.GPD.NT.6.0,USBPRINT\HPDeskjet_D1300_seriBAE2 > ;Akita > "HP Photosmart D5100 series" = > hpp51003.GPD.NT.6.0,USBPRINT\HPPhotosmart_D5100_s0169 > ;Chihuahua > "HP Photosmart D5060 series" = > hpp50603.GPD.NT.6.0,USBPRINT\HPPhotosmart_D5060_s6413 > ;Cyclops > "HP Photosmart A310 series" = > hppa3103.GPD.NT.6.0,USBPRINT\HPPhotosmart_A310_se3FA5 > > ;Bluetooth > "HP Photosmart A510 series BT" = > hppa5103.GPD.NT.6.0,BTHPRINT\HPPhotosmart_A510_se8388 > "HP Photosmart A610 series BT" = > hppa6103.GPD.NT.6.0,BTHPRINT\HPPhotosmart_A610_se9B0 > "HP Photosmart A710 series BT" = > hppa7103.GPD.NT.6.0,BTHPRINT\HPPhotosmart_A710_se1A0E > "HP Photosmart A430 series BT" = > hppa4303.GPD.NT.6.0,BTHPRINT\HPPhotosmart_A430_se7EEB > "HP Photosmart D6100 series BT" = > hpp61003.GPD.NT.6.0,BTHPRINT\HPPhotosmart_D6100_sA2D2 > "HP Photosmart D7100 series BT" = > hpp71003.GPD.NT.6.0,BTHPRINT\HPPhotosmart_D7100_s1091 > "HP Photosmart D7300 series BT" = > hpp73003.GPD.NT.6.0,BTHPRINT\HPPhotosmart_D7300_s8375 > "HP Photosmart D5100 series BT" = > hpp51003.GPD.NT.6.0,BTHPRINT\HPPhotosmart_D5100_sC1D0 > "HP Photosmart D5060 series BT"= > hpp50603.GPD.NT.6.0,BTHPRINT\HPPhotosmart_D5060_s48DA > "HP Photosmart A310 series BT" = > hppa3103.GPD.NT.6.0,BTHPRINT\HPPhotosmart_A310_se5F83 > > --------------------------------------------------------------------- > > I love some of their product names -- Beagle ..... <g> > > |
| | #8 (permalink) |
| | Re: HP printer with USB will not work with Vista (32/Premium) Yes -- I've seen their listing of dates for different products -- some of the high tech design jets and scanners they are talking of September 2007! Thanks for the additional information. |
| | #9 (permalink) |
| | Re: HP printer with USB will not work with Vista (32/Premium) That's one of the funniest things I've ever read. Vista was in beta testing forever. And HP thinks that the world revolves around them????? They should have got off their lazy ***** and done some work during testing like the rest of us. As for the others, Epson, Canon and Lexmark seem to have a lot of drivers already testing and on their sites for download. There are a few ancient Lexmarks and Epsons with problems, haven't come across any Canons yet. All my Canons are fine, ditto with my Lexmark and Epson. Sorry, not an HP anything in sight in this household. -- Cari (MS-MVP) Windows Technologies - Printing & Imaging http://www.coribright.com/windows "Char" <chpen@bellsouth.net> wrote in message news:86EA6EB9-522E-41D8-ABD1-465415A595A8@microsoft.com... >I just got off the phone with tec support at HP. They tranfered me to the > supervisor who told me that Microsoft should have waited to roll ourt > Vista > untill Hp was able to update their drivers. The drivers will be ready by > March 2nd on their site for download. Tec support got 5800 calls today > alone. > Any lexmark or cannon may take longer. > -- > Char > |
| | #10 (permalink) |
| | Re: HP printer with USB will not work with Vista (32/Premium) EUREKA…. fixe il…, correctif francais (en completant la reponse de Troels) Voici les détails : => installer HP_Vista_SF_Ph1.exe… (installe quelques pilotes supplementaires) => gestionnaire de peripheriques =>peripherique d'imprimante IEEE1284,4 => clic-droit =>"mettre a jour le pilote logiciel" =>"rechercher pilote sur mon ordinateur MANUELLEMENT" => "me laisser choisir sur mon ordinateur" => 3 choix: 1) HP LaserJet xxxxx séries (DOT4USB), 2) prise en charge d'impression USB 3) prise en charge d'impression USB DOT4 =>J'ai choisi 2) et je redemarre… (le pilote affiché sous IEEE1284,4 est remplacé par "prise en charge USB") =>panneau d'affichage d'imprimante => ajouter une imprimante locale sur port existant virtuel USB ou DOT4 hp color laserjet xxxx PCL6 (plusieurs variantes possibles) => page TEST imprimante =OK !!! Grand Merci pour ce dépannage…. |
| printer not work with vista | Vista installation & setup | |||
| cant get my hp psc 1210 printer to work with vista | Vista General | |||
| All in one printer 4 vista home premium | Vista print fax & scan | |||
| Printer(s) that work with Vista | Vista mail | |||
| I have an HP PSC 2110 All in one printer that does not work in Vista. Help? | Vista print fax & scan | |||
