| | Re: WEB Printing Problems Forwarded on a hunch to microsoft.public.windows.vista.print_fax_scan newsgroup. -- ~Robear Dyer (PA Bear) MS MVP-Windows (IE, OE, Security, Shell/User) CPenzone wrote: > I cannot print any WEB pages all I get is a printed page that shows > file://C:\DOCUME-1\Temp\XXUH0L61.htm with the date at the end of the line, > this is at the bottom of the printed page, on emails the print does not > even address the printer, so I get no quick pop up icon for email. > Previously I had a dial up0 service that had no problems, I updated > printer > driver, no luck, updated general updates from Microsoft, and Sony > (computer > Manufacturer), Any help is appreicated? |
| | Re: WEB Printing Problems Please reply if anything exciting happens, Thanks -- CAP "PA Bear" wrote: > Forwarded on a hunch to microsoft.public.windows.vista.print_fax_scan > newsgroup. > -- > ~Robear Dyer (PA Bear) > MS MVP-Windows (IE, OE, Security, Shell/User) > > CPenzone wrote: > > I cannot print any WEB pages all I get is a printed page that shows > > file://C:\DOCUME-1\Temp\XXUH0L61.htm with the date at the end of the line, > > this is at the bottom of the printed page, on emails the print does not > > even address the printer, so I get no quick pop up icon for email. > > Previously I had a dial up0 service that had no problems, I updated > > printer > > driver, no luck, updated general updates from Microsoft, and Sony > > (computer > > Manufacturer), Any help is appreicated? > > |
| Printing problems | Vista print fax & scan | |||
| Re: still problems with printing in ie7 | Vista print fax & scan | |||
| Printing Problems | Vista General | |||
| Downgrading from 64bit Vista to 32bit, Media Center problems, web page printing problems | Vista installation & setup | |||
| printing problems | Vista print fax & scan | |||
