Go Back   Vista Forums > Vista Newsgroups > Vista print fax & scan
Vista - Printer Problem - Panasonic KX P7100
Old 02-20-2007   #1 (permalink)
Mark
I take the point that we are reliant on manufacturers to improve the drivers
and iron out any incompatabilities with Vista. However, I am mystified how,
when I plugged my Panasonic in for the first time, Vista recognised it, asked
for the CD it came with, installed the drivers and I successfully printed
from it.
And then, the next day (having installed Office 2003, which may or may not
be related) the only printers listed were the Microsoft Office XPS, and the
other similar sounding one. Despite my printer being listed in the Device
Manager under the USB list. I've deleted it, tried reinstalling it, turning
off both printer and computer between attempts, but Windows has decided it no
longer recognises it and because you can't manually force Vista to recognise
USB printers ("It will load the drivers automatically"), I'm stuck with a
'dead' laser printer. None too pleased, I can say.
Any thoughts, anyone?
Old 03-26-2007   #2 (permalink)
clee666
Re: Printer Problem - Panasonic KX P7100
I have the same problem and according to thier site, they dont have any
plan to release Vista drivers...
http://panasonic.co.jp/pcc/products/.../win_vista.htm
Old 03-27-2007   #3 (permalink)
Cari \(MS-MVP\)
If you're running the 32 bit version of Vista, you can try the XP drivers,
but there's no guarantee they will work.
Old 07-29-2007   #4 (permalink)
holdenrodeo94
Hi
I too have a KX P7100, and have just built a new system which I put
Vista on (I can dual boot back to XP if I desire though.) and after
several days of head scratching and maybe a bit of swearing I think I
may have stumbled across a solution.
Firstly I used the parallel port on the printer and the printer was
detected and installed correctly. I Thought! I downloaded and used the
WinXP Drivers and setup program to install the drivers. I didn't
bother with a test print at installation time. I then went to use it
the next day and nothing just a bunch of documents in the print queue
not going anywhere.
I then tried the USB port the printer detected and showed up in the
device manager under USB devices but no show in the printers folder. I
then tried to install the WinXP Panasonic USB Drivers but they wouldn't
install Arrghhh at this stage.
I then went back to the parallel port and changed the setting and
address and communication types in the bios and whilst the computer
recognised the printer at each bios change I was still not able to
print.
I then downloaded the Vista drivers for the KX P7105/P7110 Printer from
http://panasonic.co.jp/pcc/products/.../win_vista.htm and
installed those drivers. Of course that didn't work using the p7105
Drivers. I then went back to the P7100 which was now showing in the
printers folder and it started to work. I checked what port it was on
and it was set to the KX P7100GDI Port (the panasonic USB Port).
It has now been working for about three days There seems to be a bit of
an issue with duplex printing but other than that several pages at a
time or multiple copies works.
I am not a tech nut but I suspect that maybe the USB drivers for the
7100 don't work in Vista but when you install the 7105 driver it
installs USB drivers that do work in vista so when you install over the
top of the 7100 and then choose the 7100 printer driver it automatically
uses the 7105 USB drivers and Hey it works. I'm not sure if that is so
but what do know That I have a Panasonic KX P7100 Printing in Vista.
Cheers hope this helps someone.
Old 07-20-2008   #5 (permalink)
vista home premium
I know this was thread was started a year ago but I've just installed a kx-p7100 on my vista home premium system printing to a USB port using ideas given above. It appears to work so it may be of use to others.
Plug in the kx-p7100 in a spare USB port and it will autodetect and commence installing the drivers, and at some point it will ask for the disk. If you don't have the disk you can download the drivers from the panasonic site (the xp drivers, there are no vista ones available), unzip them to a directory on the hard drive, and then install the drivers from that directory through the prompts.
It will say it is successfully installed but it doesn't actually work. Nothing will print and the printer dialog just shows an error state if you try to print. Best not try to print - just proceed to the next step.
Download the vista drivers for the kx-p7105 and install those directly from the setup routine. On my system, even after the install, no kx-p7105 showed in the list of installed printers. What it DID do however was create a SECOND panasonic KXPUSB port in the list of available ports in the printer driver properties dialog box.
Open the printer driver properties dialog box for the kx-p7100, go to the ports tab, and put a checkmark in the KXPUSB port installed by the 7105 setup routine. At that point like magic the thing started to print. I haven't tried the duplexer, I was just happy I didn't have to trash the printer.
Old 02-26-2009   #6 (permalink)
Vista Home premium 32 bit
Hi! Guys
I have tried the above and it still does not work and I have still got a dead laser printer. Would appreciate any help with a soluition.
Cheers, Ken.
Old 07-26-2009   #7 (permalink)
MMc74
Hi, recently upgraded to Vista 32 bit and WAS having the same problem
tried to load vista drivers for P7105 and no luck...uninstalled and
re-installed XP drivers from original KX-P7100 disk..vista was OK with
this and Panasonic printer was visible in printer folder after install.
I then opened Panasonic Port settings and as * MelbMarx* stated earlier
selected KXPUSB port and printer now works but does not duplex however
was able to print 2 pages in 1have'nt tried other functions but it
definately does'nt duplex any more... (in port settings the KXPUSB is
under KXP3 and looks like KXP... until you highlight with cursor)
hope this helps....another printer that does'nt need to go to the scrap
heap and at least prints (if only on 1 side)
Also I think that Melb Marx idea is good however in my case printer
worked when I installed only XP driver, KXPUSB port was available after
I had uninstalled KX- P7105 Vista driver and re-installed KX-P7100 XP
driver
Old 09-25-2009   #8 (permalink)
tdcbob
Hey, guys...you saved me and my KX-P7100. We used the VISTA driver from
the other model as suggested and we are PRINTING! Thanks a lot....
Panasonic Quiet KX-P2123 24-pin Dot Matrix Form Printer Vista print fax & scan
Panasonic KX-P7100 Vista print fax & scan
Vista driver for Panasonic KX-P7100 printer Drivers
Panasonic Printing Problem Vista print fax & scan
Problem with Panasonic NV-GS300 video camera Vista hardware & devices
