| | Vista 64-Bit, HP 820CSE and Linksys PPSX1 Print Server Problem I have an ancient HP 820CSE attached to an equally ancient Linksys PPSX1 version 1 on my home network. The printer and printer server work fine from my other computers running XP on the network, but when I try to print from Vista, the printer starts feeding the paper, hangs, and then eventually shuts down. It does not print, and I do not get a print error. I have the printer set up on the network as instructed here: http://linksys.custhelp.com/cgi-bin/...i=&p_topview=1 which is the same way the other XP computer are set up. I can ping the print server from Vista just fine. I've tried deinstalling and reinstalling the printer several times. Any ideas? Thanks |
| | Re: Vista 64-Bit, HP 820CSE and Linksys PPSX1 Print Server Problem See if Bruce Sanderson's article helps: http://members.shaw.ca/bsanders/Prin...r%20device.htm -- Cari (MS-MVP) Windows Technologies - Printing & Imaging http://www.coribright.com/windows <zbazba@gmail.com> wrote in message news:1172943425.119186.171250@z35g2000cwz.googlegroups.com... >I have an ancient HP 820CSE attached to an equally ancient Linksys > PPSX1 version 1 on my home network. The printer and printer server > work fine from my other computers running XP on the network, but when > I try to print from Vista, the printer starts feeding the paper, > hangs, and then eventually shuts down. It does not print, and I do not > get a print error. I have the printer set up on the network as > instructed here: > > http://linksys.custhelp.com/cgi-bin/...i=&p_topview=1 > > which is the same way the other XP computer are set up. I can ping > the print server from Vista just fine. > > I've tried deinstalling and reinstalling the printer several times. > > Any ideas? > > Thanks > |
| Vista and Wireless Print Server - Linksys WPS54G | Vista hardware & devices | |||
| Linksys Print server | Vista hardware & devices | |||
| Linksys Print Server | Vista print fax & scan | |||
| Linksys Print Server | Vista General | |||
| Vista 64-Bit, HP 820CSE and Linksys PPSX1 Print Server Problem | Vista print fax & scan | |||
